I’m due to install UFH (wet system) to my entire house (being renovated/extended) which will require 14 stats.
I was planning on purchasing the Heatmiser Neo stats which are approx. £55 each, digital display, hardwired. Will also need the wiring centre (£100) and remote sensor probes for in bathrooms (2).
Then discovered they are no compatible with ST. They come with their own hub (Neo Hub).
Is there anything else in this price range that will work with ST in the UK?
Heatit seems quite expensive at £99 per stat.
