[UK] Scolmore ZIgbee Sockets & Modules
Thanks!!! :+1::+1::+1::grin:
It didn’t generate the 2nd switch separately initially and i removed and paired again, redo the process. It’s working wonderfully now. Thank u!
Just received 2 of these today.
Also not picking up the 2nd switch.
I removed & re-paired but still only one device showing up.
Am I missing something?
Are you using @Mariano_Colmenarejo driver?
If so once the device is added to smartthings it will only show one side.
You need to give it 5 mins or so to load and be recognised.
Then physically turn both sides on.
Go to settings
Change them to match this
The new side will appear in No room assigned.
If not, you are probably not using the correct driver
You need Zigbee Multi Switch and Child Mc
Thanks @welshbryn.
I had not used the drivers from @Mariano_Colmenarejo.
I was trying to add them via DTH but now see that I must use Edge drivers.
I have that working now - in your instructions I incorrectly read:
If you can get your head around groovy and pasting code, this is a walk in the park.
I have now enrolled and set up as you directed.
It works for me now.
Thanks,
Declan.
Worked out for me. Thank you.
