Anyone notice a blank event (which according to logs is thermostatFanMode) every 10 mins with no data? Want to shortcut me looking at the code to hide this in my activity feed and see if anyone else has hidden them.
Are you using my deviceType from above?
I don’t have these notifications, and I’m pretty sure I removed the thermostatFanMode since the UK doesn’t use this.
Very new Smartthings user here, only bought my kit at the weekend but I already had Nest G3. Got the original code working yesterday and then started messing with the code tonight to take out the non UK stuff but just found this code. Pasted it in and it works a treat, thanks Very happy and thank you for your efforts.
Quick question, is it possible to set the Nest to Away as part of the ‘Goodbye’ routine?
I’ve purchased and installed 2 3rd gen nests and would now like to add them ST.
I just have 2 questions if anybody could help?.
If I use the device type in this thread, can my nest also be used as a presence sensor?. I’ve read somewhere before this is not exposed in the API however one of its config settings is presence?.
Will this device type continue to poll or is there still an issue with polling?. Can’t see a really valid use for my setup if ST is not reporting temp for me without needing to refresh.
having issues having added smart apps and code from link above.
Can I start of from saying I am not a developer and a simple user who is trying to add nest support in the UK.
Firstly I was not able to add Git Hub update from Repo with the Eu west IDE link. (https://graph-eu01-euwest1.api.smartthings.com) so logged in under (https://graph.api.smartthings.com/ide/devices) added link and copied smart app code and thermostat code and added manually as a new smart app and device under my euwest link which shows the home hub and devices.
All looked well in that temperature was correctly shown, however I cannot change the temperature.
So try to remove app then device however I clicking remove a error is created 'an unexpected error has occurred’
Now I tried to be clever here and altered the app to Feed Barkley and then try to remove.
However on trying to remove I got a message stating the device is in use, so now have a circular issue cannot remove device as smart app installed and cannot remove smart app as device in use.
so added original Nest manager code back but now stuck on how to remove
As posted above I used this code and was really pleased with it for a focused UK version with none of the components we don’t use. However I’ve since started to use the Nest Manager App which is based on the Official exposed API’s from Nest and it includes the Protects within the app capability. So I’m now back to a US focused App with HVAC controls we don’t use etc. Would it be possible or would anyone else be interested in a UK port of the Nest Manager? I think that would then be a really good UK Nest SmartApp.
I think what @andyjh was getting at is that my device type is specific to the UK, where as the Nest Manager one isn’t.
The Nest Manager one still works, but it also supports things like A/C and Fan mode which we don’t have in the UK due to having a water based heating system as apposed to air.
If you actually send Nest US commands to the UK thermostat, it temporarily unlocks the features. They don’t do anything, but they accept the commands
It’s just very difficult to automate some of this stuff because of the limitations of the device handler and dynamic tile loading. We will look for a way to achieve this. It may require us to create an alternate device handler that can be selected before the devices are installed. Maybe we can add in the alternate tile code for the UK and users can just comment them out.(This may be a pain because it would be overwritten when there are updates
Yes @ghesp, that was what I was meaning, the Nest Manager works for UK Nest’s but contains tile graphics for commands that don’t work for us.
@tonesto7, to have a one size fits all Manager App would be fantastic but I realise this would be low down on your priorities! Personally I would love it to happen if it was simple but I wouldn’t want it to distract from the good work you are doing for all with the Manager. I assume to comment out the sections that aren’t relevant to us in the UK is fairly straightforward, apart from having to do this at every update but it would be the restructuring of the tiles that would be more of a pain. Unless you could ‘borrow’ the tile layout from the port in this thread, comment out the a/c fan sections and see if it works? Just an idea to try if you get some time.
Thanks for all your hard work so far with this app though
To be honest, it shouldn’t be too hard to just add a setting option anid display the relevant layout based country.
That depends on the logic of the app though
If it were only that easy. There is no published way to accomplish this currently. I have had the code in there to do it since day 1. The apps will not honor it though
I guess if it can’t be handled automatically by the app due to limitations then having something that UK users can manually edit would probably be a pragmatic way forward, if possible. Leave it defaulted to US users as the biggest population, any UK user who doesn’t want to edit can still use but have features displayed that can’t be used, those that are confident to make the alterations then can. Don’t know if that could be an approach without causing too much effort and solutioning? Just happy that you are considering it though
