So I’ve managed to add the blind motor and install the tuya window shade driver from iquix however when I try the open and close option it only turns once. Having not added a third party blind edge driver for a blind I’m not sure how you set the max drop or if it’s a issue with the driver.
Hi @iamjezz I’m in the exact same position as you. I already added the device to SmartThings using @iquix’s driver, but can’t figure out how to set the limits (I don’t have a Tuya hub either).
Still looking around/doing some research, but reaching out in case you’ve already figured it out.
I managed to do it but just pushing multiple buttons but don’t have the correct order.
However to set the height I put the blind in the lowest position. Pushed the up and down till the light blinks , push the up or down till your blind goes to the up position I want and push the two up/down buttons again
