Hi Nayeliz, thanks for your help
I’m integrating TUYA into ST with the ST Android APP ( Pressing “+” -> Device -> TUYA). The device it’s working in the ST Android APP, and also I can see the status in graph.api.smartthings.com
My SmartAPP source code is
const express = require(‘express’);
const SmartApp = require(’@smartthings/smartapp’);
const server = module.exports = express();
const PORT = 3003;
const mqtt=require(‘mqtt’);
const config=require(’…/MQTT_Homie/config’);
var bbdd=require(’…/bbdd’);
server.use(express.json());
var mqttClient = mqtt.connect(config.MQTT.broker,{username:“XXX”,password:“XXX”});
/* Define the SmartApp */
const smartapp = new SmartApp()
// @smartthings_rsa.pub is your on-disk public key
// If you do not have it yet, omit publicKey()
//.publicKey('@smartthings_rsa.pub') // optional until app verified
//.enableEventLogging(2) // logs all lifecycle event requests and responses as pretty-printed JSON. Omit in production
.configureI18n()
.permissions([
"r:devices:*",
"w:devices:*",
"x:devices:*",
"r:locations:*"
.page('mainPage', (context, page, configData) => {
page.section('contact', section => {
section
.name('Sensores de contacto')
.deviceSetting('contactSensor')
.capabilities(['contactSensor'])
.multiple(true)
.required(false);
page.section('temperature', section => {
section
.deviceSetting('temperatureMeasurement')
.capabilities(['temperatureMeasurement'])
.multiple(true)
.required(false);
page.section('acceleration', section => {
section
.deviceSetting('accelerationSensor')
.capabilities(['accelerationSensor'])
.multiple(true)
.required(false);
page.section('lights', section => {
section
.deviceSetting('lights')
.capabilities(['switch'])
.multiple(true)
.permissions('rx');
page.section('motion', section => {
section
.deviceSetting('motionSensor')
.capabilities(['motionSensor'])
.multiple(true)
.required(false);
page.section('water', section => {
section
.deviceSetting('waterSensor')
.capabilities(['waterSensor'])
.multiple(true)
.required(false);
page.section('switchDev', section => {
section
.deviceSetting('switchD')
.multiple(true)
.required(false);
.updated(async (context, updateData) => {
// Called for both INSTALLED and UPDATED lifecycle events if there is no separate installed() handler
await context.api.subscriptions.unsubscribeAll()
//motion
context.api.subscriptions.subscribeToDevices(context.config.motionSensor,'motionSensor','motion','motionSensorEventHandler');
context.api.subscriptions.subscribeToDevices(context.config.motionSensor, 'temperatureMeasurement', 'temperature', 'temperatureMeasurementEventHandler');
//multipurpose
context.api.subscriptions.subscribeToDevices(context.config.contactSensor, 'contactSensor', 'contact', 'contactSensorEventHandler');
context.api.subscriptions.subscribeToDevices(context.config.contactSensor, 'accelerationSensor', 'acceleration', 'accelerationSensorEventHandler');
context.api.subscriptions.subscribeToDevices(context.config.contactSensor, 'temperatureMeasurement', 'temperature', 'temperatureMeasurementEventHandler');
//water
context.api.subscriptions.subscribeToDevices(context.config.waterSensor, 'waterSensor', 'water', 'waterSensorEventHandler');
context.api.subscriptions.subscribeToDevices(context.config.waterSensor, 'temperatureMeasurement', 'temperature', 'temperatureMeasurementEventHandler');
//switch
//context.api.subscriptions.subscribeToDevices(context.config.switchD, 'switch', 'switch.on', 'switchSensorEventHandler');
context.api.subscriptions.subscribeToCapability("switch","switch.on","switchSensorEventHandler");
.subscribedEventHandler('motionSensorEventHandler', (context, event) => {
const smartappId=context.event.appId;
var viviendaID=bbdd.getViviendaID(smartappId);
const value = event.value === 'active' ? '1' : '0';
console.log("El motion sensor detecta "+value);
if(mqttClient.connected)
mqttClient.publish("homie-"+viviendaID+"/"+event.deviceId+"/"+event.deviceId+"/"+event.capability,value);
//context.api.devices.sendCommands(context.config.lights, 'switch', value);
//handlers multiPurpose
.subscribedEventHandler('contactSensorEventHandler', (context, event) => {
const value = event.value === 'open' ? '1' : '0';
console.log("El contact sensor está "+value);
console.log("homie-"+viviendaID+"/"+event.deviceId+"/"+event.deviceId+"/"+event.capability);
.subscribedEventHandler('accelerationSensorEventHandler', (context, event) => {
const value = event.value;
console.log("La aceleración: "+value);
.subscribedEventHandler('temperatureMeasurementEventHandler', (context, event) => {
console.log("La temperatura en "+event.deviceId+" es: "+value);
.subscribedEventHandler('waterSensorEventHandler', (context, event) => {
console.log("Detección de agua EN "+event.deviceId+" es: "+value);
.subscribedEventHandler('switchSensorEventHandler', (context, event) => {
console.log("ON");
/*console.log("Detección de agua en "+event.deviceId+" es: "+value);
mqttClient.publish("homie-"+viviendaID+"/"+event.deviceId+"/"+event.deviceId+"/"+event.capability,value);*/
/* Handle POST requests */
server.post(’/’, function(req, res, next) {
smartapp.handleHttpCallback(req, res);
/* Start listening at your defined PORT */
server.listen(PORT, () => console.log(Server is up and running on port ${PORT}
