Tuya IR Blaster with Air Con Layot
Hi everyone, I have recently purchase cheap Chinese tuya IR Blaster and trying to integrate it. from community post i saw that some users have same device with same manufacturer and model number integrated and using Otivax - Zigbee IR Remote Control. in the begging i have integrated my blaster using this driver however the remote layout in my application appeared only for tv, i checked and tries learning option and it was working and i managed to learn this blaster for my Air Con ir commands, but it is not very comfortable to use tv layout on AC. then i Tried using Device profile builder and even Edge driver builder, the layout changed but learning capabilities was lost. then using AI i star to make my own EDGE Driver and i managed to upload it on my hub. it was 1st attempt and i added only on/off and temperature slider, learning capabilities was postponed for next day. same time i tried to build custom capabilities, i finished process it appeared in device profile builder but when i added it never come alive, even on web page it place was blank, only if reediting i was able to confirm that learning capabilities was added, but outside not visible/usable. on next day using AI I have added learning capabilities but after that whenever i add this device it only appears as a zigbee switch, but i can change driver with otivax ir driver, my new driver is assigned to channel it visible on my hub but not assignable to device.
my device model is TS1201. My driver includes **IR learning, AC mode, fan speed, swing, and temperature setting.
The problem is: even though I can upload the driver and see it in the hub and channel, when I add the device to my hub it always shows up as a generic Zigbee switch. No IR learning buttons, no AC controls — just a switch. On some hubs, even the signal or data tables disappear. but Otivax driver is working. also when i try to change devices in Otivax driver i am getting notification of server error, and i was not able to make learning for TV remote control, if anybody can take a look on my driver and assist or share a ir edge driver with Air Con controntrol layout it will be great, maybe i am mistaken but there are not a lot of ir blaster driver. is it safe to share codes here? Thanks in advance
