I have a ST hub as a secondary controller to a Tuxedo Touch zwave controller. I have followed the directions on here for the integration and it worked fine. Only thing extra was renaming all the zwave device that imported to ST to their correct names. Shortly after the install / integration I tried to install a new zwave device to the tuxedo touch since it is the primary controller, and I was not able to register the new device with the ST since it was a secondary controller and noticed it did not sync.
I then removed my ST controller from the tuxedo to follow steps again to the integration and was unsuccessful. Since I was still in my 30 day trial period I ordered a new ST and tried integration and all worked great in closing the new zwave device.
Fast forward to a year today and I have added multiple new zwave devices.
Can someone walk me through the process of syncing or adding these new devices registered to the tux to the ST. I don’t want to end up with a broken process again and having to buy a new ST.
Also is there a way to register straight to the ST while paired to the tux as a secondary controller.
You probably already figured this out, but for those finding this thread in the future:
While it is technically possible to add The smartthings hub as a secondary controller to another Z wave network, it probably won’t work the way you want. For one thing, Only the devices present at the time of the original join will be available to smartthings. If you add additional Z wave devices later, You have to exclude the smartthings hub and then re-add it again. Also, some devices will not work with it or even be visible to it.
For these reasons and more, SmartThings support does not recommend using it as a zwave secondary and will not support it if you do.
So you shouldn’t have to buy a new smartthings hub, but you would have to remove it from your primary network and then add it back again.
Thank you for the response. Can someone post a step by step procedure how to synce the tux with the ST.
Also what will I loose if anything by doing this. 1) I have created scenes on the smartthings hub, will I loose this when doing the sync.
I have my Total Connect alarm system working with the smartThings and works extremely well. Will this break when syncing in the new zwave devices?
i also have Alexa tied in and workings great.
would it be possible to sync in another hub and have it work with tux and my first ST hub.
Basically I am only registering the zwave devices to the tuxedo. All the scenes are at the ST device. And I am using my Total Connect with ST with my phone as a presence sensor.
Furthermore I am a newbie and finally have this setup and afraid to break it :-). If there books or websites that can educate myself please let me know where.
