I’m trying to get this heater on for just 1 hour on weekdays ONLY if presence is detected between 8am and midday…
The thing is I only need it to turn on ONCE… but right now… if any of the people with presence devices go into the geofence… The heater turns on… even if it was on just a few seconds before!
I’ve done this piston:
IF
● Any of Daniel or Laura presence changes to present
◦ Time is between 8:00 AM CET and noon
THEN...
Using Caldera...
► Turn on
► Send notification 'Caldera Encendida' to [Daniel - PUSH]
I would use a virtual switch that gets turned on with the heater. Then add the condition that this switch must be off along with your original presence for the heater to turn on. After the time period is over have another piston turn off the virtual switch. Unless I’m missing something, this should work.
ok… I get your point… let’s assume we want it just once per day… no matter the time… so if I suffer an insomnia attack and go to work at 4… I will have warm water… but it will not do it again until the next day…
If
Any of Daniel or Laura changes to present
Then (on state change only)
Using Caldera, Turn On
But If
Time happens at midnight (or whenever you want it to reset)
[no actions]
