Turn on light with doorbell, and shut it off, unless it was already on
Hey all- I was fairly well-versed back in the Groovy days, but after some time I’m trying to get reacquainted now.
Can I do this with the “Smart lighting” app? Or perhaps with normal Routines? So far I’m stuck.
When someone rings the doorbell (in Smart lighting, this is a button press), I want to turn on my foyer lights. Then after 10 minutes, I want them to go off again. However, if the foyer lights were already on, then don’t do the auto-off.
With routines, I can make a condition for “lights not on” + “doorbell pressed”, which should work, other than I want other things to happen whether the lights are on or not.
Using smart lighting, the auto-off functionality is only available when the action is “turn off”.
I guess I don’t understand the use case. If the light is already on, then why do anything when the doorbell is pressed?
If the light is off, use a precondition in your Routine to check the state of the light when the triggering event (doorbell pressed) happens:
If Light is off (precondition)
   Button is pressed
Then
   Turn on light with auto-off after 10 mins
My hope was to have one routine responding to the doorbell, and it would do like 3 things (take a picture, turn on this light, text me, or something like that). The more I think of it, I could just have two different routines, one for the foyer light (with preconditions like you mentioned), and another for the other things.
Thanks,
Korey
Yes, I think you need two Routines because you want the light to be turned on only when it is off and you want the other things to happen all the time.
That is a (renamed) feature carried across from the old Smart Lighting app. It just turns a device off when it has been on for a certain period of time.
The Smart Lighting app is basically leading you through a process of selecting one of a number of templated rules without you noticing and then configuring it. So if your scenario isn’t one covered by a template you are out of luck. On the plus side the templates may sometimes handle more complex tasks than a single Routine can.
