Turn off ring camera with guest mode
Is there any way to turn off the ring camera when I’m in guest mode (a mode the disarms the house) so that it doesn’t keep going off every 2 seconds when people are coming and going
You could disable the motion notifications in the Ring App and use ST to notify you of motion…
This is how I have mines setup. I use webCoRE for my motion notification rules. Didn’t like the constant spamming of motions either so I set up when and what motions notifications I would receive.
For Example,
If all adults are not present
And
Motion changes to active
And
Front door did not open in the last 3 minutes
Then send notification, “Someone is at the Front Door”
I leave the notification of the actual push of the doorbell to Ring so I can easily bring up the Video Feed…
YMMV
That would work do you have some Pistons that you might be able to share?
