I’m trying to understand why some things are displayed in the Smart Home Monitor dashboard and others not.
For simplicity and testing, I have a hub that has only one device connected, a ST Water Leak Sensor. After the sensor connected without issue, I went to the Smart Home Monitor Dashboard and using the Setup menu, designed a push and sms notification for a leak. This notification fires as designed when the probes get wet.
At this point, when I view the Smart Home Monitor Dashboard, it has an entry for “Leaks” that displays appropriately, either showing “ok” or showing a leak.
I then went back into the Setup menu and configured a 2nd rule (via custom) for temperature with a push and sms notification for when the temperature drops below a certain point. This notification also fires as designed when the temperature drops below the threshold.
My question is why I don’t see a 2nd entry for the temperature rule when I return to the Smart Home Monitor Dashboard. I have 2 rules, both working properly. I see the status entry for the “Leak” rule, and I would expect to see a status entry for the “Temperature” rule as well, but I don’t.
Why do I have a status entry for one but not the other? The notifications work and I know I can go the the individual device via the My Home tab, but it seems to be that there ought to be a status entry for each rule in the Smart Home Monitor.
