hi
I am trying to write a small apps that do on/off/on/off for a switch that will activate a garage opener,
but if i use subscribe i get into an endless loop/ anyone have idea how to do it ?
hi
Where are you getting an endless loop? Do you have code already written?
Also, I have a WebCoRE piston already written for this. I was thinking about porting it to groovy but awesome you’re getting started. I can share the Piston for the logic I use.
Can you share your code and also why you need to write a smartapp for that?
To me, a Device Handler is responsible to On/Off a device. I made several. Some are just sending the On/Off without transitions, some send the command and wait the device to acknowledge it to modify state.
Now a Smartapp would be there to manage event in order to connect other devices or sent notifications but I would not have it managing the on/off as it will basically send a Off upon reception of a On event and vice versa. That’s maybe what happens to you.
hi Phiplippe
see the code i did a trick to avoid the loop but it is not working good
can you send an example for device handler that do switch on/off/on/off with 2 sec delay between each state
Copyright 2015 SmartThings
- Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
- Garage Door Opener
- Author: SmartThings
definition(
name: “My Garage Door Opener”,
namespace: “smartthings”,
author: “SmartThings”,
description: “Open your garage door when a switch is turned on.”,
category: “Convenience”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Meta/garage_outlet.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Meta/garage_outlet@2x.png”
)preferences {
section(“When the garage door switch is turned on, open the garage door…”) {
input “outlet1”, “capability.switch”
}def installed() {
subscribeToCommand(outlet1, “on”, onCommand)
}def updated() {
unsubscribe()
}def onCommand(evt) {
unsubscribe()
log.debug “event name: ${evt.name}”
log.debug “event value: ${evt.value}”
log.debug “onCommand1: $evt.value, $evt”
outlet1?.off(delay: 2000)
log.debug “onCommand2: $evt.value, $evt”
outlet1?.on(delay: 2000)
log.debug “onCommand3: $evt.value, $evt”
runIn( 8, mySubscribe )
}def mySubscribe () {
// subscribe(outlet1, “switch”, handlerMethod)
subscribeToCommand(outlet1, “on”, onCommand)}
def appTouchHandler(evt) {
log.debug “appTouch: $evt.value, $evt”
outlet1?.on()}
austin,
i shared the code below i am not familiar with WebCore will try to read on that.
can you share the piston for the logic?
Here’s the piston I use. Also a scan from when I was coming up with the logic. I use my door with a FortrezZ MIMOLite, a momentary relay. Some considerations had to be taken into account.
-Disable command Optimizations - Sends the "on event even if the relay is already on. More of a WebCoRE thing and not important to Groovy.
-Refresh command is sent 2 seconds after event. This is done as a means to try to keep the relay state right because it turns off faster than ST refreshes. A linear opener won’t have this issue.
