Anyone know if these will work with Smartthings?
It does, locally via Matter bridge if you also have the Tapo H110 hub since the Tapo H100 and H200 still do not have the Matter 1.3 firmware update (there’s a beta though).
Unless you have it already have it consider ikea matter over thread water sensor which won’t have a dependency on a tapo hub. Probably cheaper too
Provided you have v3 or v4 hub
I have V2 Smartthings hub.
Ok, not an option then unless you have an external tbr like a echo device with tbr built in or some other thread border router
