TP-Link/Kasa Bulbs and Plugs Control
dth_wallswitch
dth_smartbulb
dth_lighting
dth_pocketsocket
dth_outlet
(Dave Gutheinz) #609
It can only turn on and off. So no other testing should be required
I will update the master file when I get home. Since you already modified, no change for you.
Dave
(Mark Slagle) #610
So, I have been using the TP Link connector successfully for a while now. The other day I went to add some new devices, which it see, but when I select them and choose next I get “An Unexpected Error Has Occured” I have tried to remove the app from smartthings, I get the same unexpected error. No matter what I do, I cannot install devices, remove the app or anything, only get unexpected errors. I’m stuck and need some guidance.
(Dave Gutheinz) #611
Usually caused by service manager version not compatible with device handler. You need to update all to latest and try again. Should not affect other devices. Good luck.
(Mark Slagle) #612
Okay, I’m trying to do this now, but the device handlers are named differently than what I have installed. For example, I have one call TP-LinkHS110 Emeter, I don’t see one like that listed anymore to update.
(Dave Gutheinz) #613
Correct. I had to rework to add Github integration. Simply replace content files and save.
(Mark Slagle) #614
I’ve done this, replaced all the dev. handlers, and updated the manager. I am still getting Unknown Error has Occurred. It sees all 7 devices, and I select them, click next, that’s where the Unknown Error appears.
(Mark Slagle) #615
Okay, so I got it to install my HS200 switches, if I select them only. But my LB120 tunable bulbs are still giving the Unknown error.
(Dave Gutheinz) #616
What are the devices??? Some very new models of TP-Link have not yet been updated.
(Dave Gutheinz) #617
I will have to look tomorrow. Out of town consulting.
(Mark Slagle) #618
I figured it out. I added the tunable white dev handler without e-metering, even though mine do this, and now it works. Thanks for your help!
(Mark Slagle) #619
Hi Dave, one last question. I notice that the circadian option now appears for the tunable bulbs. Is there a way to add that functionality into a scene or routine? Right now I can only modify the color temp and brightness. Thanks!
-mark
(Dave Gutheinz) #620
Probably a limitation. It is s command; however not associated with a capability. We core may be able to??
