This is typically caused by not pasting the entire file correctly. That is easy to do (for some reason). Try re-copying the content and then repasting.
The first two lines should look like (exactly)
TP-Link Connect Service Manager, 2018 Version 2
Hi everyone I am pretty new to all of this and I am trying to copy the code for the tp link cloud. I opened the link and see the code but I am not sure where to start copying from. I have tried to start the copying from line 37 metadata all the way to the end but when I try to create it. this is the error it gives me.
No signature of method: script_app_metadata_2b3121c2_5e01_4bdc_a20e_af2864cc9725.metadata() is applicable for argument types: (script_app_metadata_2b3121c2_5e01_4bdc_a20e_af2864cc9725$_run_closure1) values: [script_app_metadata_2b3121c2_5e01_4bdc_a20e_af2864cc9725$_run_closure1@d864e86] Possible solutions: getMetadata(), getState(), setState(java.lang.Object), metaClass(groovy.lang.Closure)
sorry i just read the earlier message and I tried copying the whole thing and still gettting this error
No signature of method: script_app_metadata_7a207dd4_e413_4eac_9b14_4fa3dedb3115.metadata() is applicable for argument types: (script_app_metadata_7a207dd4_e413_4eac_9b14_4fa3dedb3115$_run_closure1) values: [script_app_metadata_7a207dd4_e413_4eac_9b14_4fa3dedb3115$_run_closure1@74927ade] Possible solutions: getMetadata(), getState(), setState(java.lang.Object), metaClass(groovy.lang.Closure)
Welcome to the world of technology. Ainât it wonderful.
You must copy everything in the files to assure that it will work. Common errors are copying Device Handler file into the Smart App page and vice-a-versa, so follow instructions closely.
Hi Dave thannks for the quick reply and thank you for providing this code. I did try following the directions from your PDF and made sure that I was in the my smartapps tab before clicking new smart app but unfortuneatly it is still giving me the same error. I also put the file in raw mode and copied the entire code.
sorry dave i think I know where I went wrong. I was copying the device handler code in to the smartapp. Now the question is where is the smartapp code?
You are definitely trying to load the Device Handler into the Smart App space. Smart App is on server under (I believe) Service Manager or Smart App. You need both for installation.
awesome i found it and installed very easy thank you for your help and hard work. I just want to ask one final question. As I am looking at the plugs and switches from the smartthings app, I noticed that I only have the option to turn on or off. If i have previously set up schedules from the kasa app, will they still work and if not what are my options?
The schedules set up in the Kasa App will still work. Additionally, you can use the SmartThings Automations to control the switches along with other items. For example, I have a âSleepâ automation. It turns off ALL lights and switches in the house (with a few exceptions), sets the Thermostat for sleeping, and locks the front door. I have another âWakeâ, that turns on some lights and other switches, sets the Thermostat for daytime., etc.
So Iâve got the âCloudâ method working using the legacy app. It seems that with the new app, the devices are stuck in a âChecking statusâ mode, and never do allow for the power to be set on/off or used in an automation/scene.
Is this expected, it seems that with the legacy app - I can do all of this, so I may just remain on that app until this support is available.
What are others doing for this, or whatâs the roadmap for support in the new(er) app?
I assume you are discussing the new SmartThings app. I have not tried this with these devices since that app (last I looked) was not ready for prime time. When I can actually use the new App, I will fix what they have broken.
Exactly, thank you. As it is, it seems the new App has some nice UI â but isnât quite ready for prime time when doing anything but the basics. Hopefully they get there, but until then, the âClassicâ app will do the trick.
All: Mistakenly ordered the HS103PS from an Amazon deal. These devices are listed on their site as HS103PS but the model is HS103. I was able to update the model definition on line 172 of the TP-Link (unofficial) Connect app:
tpLinkModel << [âHS103â : âTP-LinkHS-Seriesâ]
Saved and published. Seems to work fine but I have only tested it for about an hour. OP: Is there any other testing I should do?
