I am preparing to update the system to the next version, cleaning up some displays and assuring all is working OK.
ANY SUGGESTIONS?
ANY SUGGESTIONS?
Dave - I followed the complete instructions for install of the TP-Link App and used the phone to log into my cloud account with TP-Link.
I selected the device in the phone app, but canât seem to get it to show in My Home > Things
Any ideas? It could be something to do with Locations as the instructions are not clear on that selection if you are logged into SmartThings graph webpage.
Sorry you are having problems. Log onto the IDE and then select your location. Look at the device handler page and see if the device handlers are there. Do the same on the Smart Aps page for the Service Manager.
You stated âI selected the device in the phone app, but canât seem to get it to show in My Home > Thingsâ. What app are you talking about selecting the device in?
I think the instructions are clear - see extract below.
d. Select the âMy Locationâ Tab and select your location.
[NOTE: YOU MUST SELECT YOUR LOCATION. NOT DOING SO WILL CAUSE THE SERVICE MANAGER TO NOT APPEAR IN STEP 5C AND THE DEVICES TO INSTALL IN STEP 6B.]
Your location is probably the only item in the list. The selection is done under the Name column by selecting the location name.
Get back to me if you are still having problems. We will have to do more troubleshooting.
Yep - you are correct Home is the only option and the one I selected when installing the code and for both the Device and the Smart App.
The thing is that when you select Home and it just takes you to a page displaying these details:
How can I correct this now that everything is installed on both the iPhone app and the IDE?
Unless you blanked out some data, I think this is a basic SmartThings problem (in your installation). I believe (and in my account) that the following should be included (specific to your location:
Account XXX.@YYY.comâs Account
Coordinates 32.135136 N, 95.89188 W
Time Zone America/Chicago
Weather
Sunrise 7:14 AM
Sunset 5:20 PM
Temperature Scale F
Alarm System Status Disarmed
Current Mode Home
FROM your screen above, select Devices (toward the bottom). It should list the devices associated and it should include the TP Link.
Also from the screen above, select âList Smart Apsâ. It should take you to a screen with smart apps (including the TP-Link smart app.
If not, you have something wrong in the SmartThings installation (I think).
Great. Now, at the top go to âMy Device Handlersâ. It will show the Device Handlers page. You should see one of the following device handlers:
beta : TP-LinkHS-Series Published Actuator, Polling, Refresh, Sensor, Switch
beta : TP-LinkLB100-110 Published Actuator, Refresh, Sensor, Switch, Switch Level
beta : TP-LinkLB120 Published Actuator, Color Temperature, Refresh, Sensor, Switch, Switch Level
beta : TP-LinkLB130 Published Actuator, Color Control, Color Temperature, Refresh, Sensor, Switch, Switch Level
I just have TP-LinkHS-Series - should I have all of them? I am not using the lightblubs
No. Just the TP-LinkHS-Series
Next, let us redo the installation (I have pictures if you need for any step).
Select Your TP-Link Devices page
Selected Devices page:
The Automation page with a green success banner should appear and the device should be there.
Pics would be great
Yep - did all of that and still nothing showing up.
When I go to the log in the IDE and try to add and or update the token - the requests show, but no device even is listed in the app.
I just noticed this:
You may not have the device in remote control (done in the Kasa ap).
