I have motion alerts for outside (BlueIris does the alert and then trips a sensor in SmartThings, from that I can do anything like turn on lights etc)
I have it pipe the video feed into ActionTiles (a web panel for SmartThings - search the forums for info or go to www.actiontiles.com) I have several tablets around the house running this so I can view cameras all the time
You can also pipe the feed direct into the SmartThings app if you want to view the stream via the iOS app (not sure about android) using the Generic Video Camera App (think that’s it name)
Seriously look at ActionTiles though - good bit of kit
Kraeg
Zwave should be compatible with SmartThings, although some older “scene controllers” may not work as expected. And because zwave frequency varies by region, you have to make sure you’re ordering one that has the correct frequency for your hub.
Zigbee is a whole different story. There are many zigbee devices that do not work with SmartThings. See:
And I second the recommendation for Vesternet. Excellent technical support, good technical information on the website, good selection. Not everything there will work with SmartThings, so always check the forums before ordering, but it’s definitely one of the dealers to consider:
There are some more shop options listed in the following thread:
I too am I the UK and constantly adding to my system. I find the ST multi-sensors are pretty good and as well as monitoring open/closed states they monitor temperature so I use one of mine to control a heater in my office.
I have also just installed 2x Ring outdoor cams which although not supported on ST yet, the doorbells are so the cams should not be far behind. They are battery powered so installation was easy and I have to recharge them every couple of months.
Hive is awesome and there is a hive app on here which works well and allows you to setup rules for home/Away and temperature actions.
Lastly if you have hue these integrate well with ST. Don’t forget to install CoRE as it allows far greater control over everything.
I think people have covered most things lol
I’m similar to you but I’ve had SmartThings set up now for 3 weeks and am loving it so far…
I bought the starter kit which all work well the little presence sensor is good I’ve hooked it up to my sons keyring and me and my wife now get a notification when he’s home from school safe.
My motion sensor is in the hall set to turn on my downstairs lamps on when it detects us in the morning
I was recommended Xiaomi products from Ali express as they are dirt cheap compared to official ones and have 3 door/window sensors a push button that when pressed at night it turns everything of and turns alarm to on.
I want to get a outside camera next so will be looking at any recommendations you get lol.
That sounds great. A good start to the system if you work the cameras first let me know as your system as it stands sound very similar to what I would be doing.
I’m not sure I’ll be getting the camera just yet as the next thing I want is the Nest thermostat
I looked at them on display in Currys and they just look really smart and have a nice finish which I prefer to Hive.
I do already have a “sumvision” internal WiFi camera that is not officially supported but there’s a smartapp that’s supposed to connect to it but can’t for the life of me figure out the right connection RTSP stream even though it connects on my laptop.
I also have 6 Sonoff devices as I’m a tight sod and they’re only a fiver each delivered from China and I’ve flashed them to work with SmartThings and I lot them on lamps in the bedrooms where I don’t see the wires as you have to snip the cable and fit them in place.
UK user here. Some info about what I have setup. No right or wrong answer, the info below might just give you some lines of enquiry.
2 external cameras:
I too am a user of BlueIris. Solid product. I have 7 cameras hooked up to it and I generally keep that solution separate to ST. The only exception there would be the fact that I use one of the camera feeds on an ActionTiles panel via a tablet. That said other users are using BI to detect motion and then carry out actions within ST.
4 door sensors
I use a combination of ST, Orvibo and Xiaomi. As discussed above ST sensors give you temp and vibration but if you just want basic open/closed detection and you property is not huge then go with the Xiaomi or Orvibo. Solid bits of kit and shouldn’t cost you much more than a tenner each.
External Sounder (alarm style)
Don’t use one. I have a separate old school alarm panel. I use ST to control the home environment and provide information when I’m away, for example: When I’m away the heating goes down to 10, lighting changes so that it comes on (as opposed to motion based when at home), garage door is diabled, etc, etc. I rely on the alarm to scare off Burglars and keep neighbours swearing.
Control of heating
I’ve got a 3 zone heating system. All controlled using a community developed handler. I have 3 battery powered z-wave thermostats that cost me about £40 each set on eBay (search Secure or Horstmann).
Pet immune type sensors
Not sure here, haven’t researched it heavily enough. Question here is you have door/window sensors on all entry/exit points then do you need to use motion sensors for security. Note that my alarm system has wireless pet immune IR sensors on it.
Couple of other points.
CoRE - Get this installed and have a read around it. It’s an essential component of the ST toolkit. If a Smart App doesn’t exist for your requirement then CoRE can do it. This is a very clever if X then Y else Z rule engine. Quick use case: I have a TKB z-wave metering socket on the tumble dryer. CoRE is setup with the following rule: When power drops below 10W for more than 120 seconds send a push notification stating “Tumble Dryer has finished”. It’s the little things that matter!
This community and search is your friend. The amount of co-operation and willing to assist from members is awesome.
Also in the UK, Smartthings Starter kit arrived last week. I already had a Nest thermostat, harmony hub, LIFX LED strip and a couple of TP-link power switches.
The only additional thing I’d say is: Lots of the devices in my setup will integrate with each other directly, but that gets confusing pretty fast. Stick to one place (almost certainly SmartThings) to do most of your logic, utilising IFTTT for any rough edges (I’m using IFTTT mainly for Google Assistant integration and a couple of notifications unrelated to my home)
Best rule so far: (Using CoRE) If no motion detected in the living room for 5 minutes and TV Smartplug power is less that 15W (ie: TV on standby, no-one around) switch off the Smartplug (and tell harmony to switch off the rest of the AV system).
Paired with motion sensor switching it back on when someone enters the room
I’m now going to let things lie for a while so my wife gets used to it before sticking some fibaro switches on my lights.
Oh, and I’m planning on hunting for & updateing/writing a new UK-focussed getting started guide - Some of the info around GitHub integration and IFTTT is quite out of date
Hi paul. A very good point on the door and window sensors and not putting in passive detectors if not needed especially at £10 each compared to circa £75 for the passive.
I like your tumble dryer mod I may do the same
Without sounding stupid what is the integration from the cameras to the blue iris. From a quick scout it looks like a pc based system so do you need to have a pc on all the time ?
What are you using as a main brain ? Any recommendations there.
Thanks for the help
kind Regards Jeff
I’m using a dedicated PC running BlueIris. I’m assuming by main brain you mean PC. If not let me know.
Its quite a decent spec PC but there’s a setting I’ve since found which reduces the CPU requirement of the machine:
I have 7 HD cameras and the PC runs at about 7-8% CPU with the above setting enabled. The PC in question also does a couple of other things for me so its not solely dedicated to running BlueIris. In fact it also runs this:
Which I use to detect various frequent visitors as I have their phones on DHCP reservations.
BlueIris integration here:
Note that I’ve not gotten around to this but its on the to do list.
Cheers paul I was meaning the hub it all connects thru.
Do you know of any external cameras that integrate straight in without the pc ?
Apologies for so many questions.
Not bad. It’s a fun learning curve discovering what can be done easily and what’s slightly more difficult.
When I first tried to do some custom integrations I did end up on the wrong graph.api.smartthings.com to start with and was really confused that I couldn’t see my hub!
Example 1: Harmony will integrate with SmartThings and control switches. Brilliant I thought. Then I discover that Harmony Activities always execute “Home Automation” devices after “Home Entertainment” devices, so I can’t tell it to switch on my TV at the wall, then wake it up from standby - I’ve now got a SmartThings routine that does do that (ie: it switches on the socket, then triggers the Harmony Activity) but it’s a bit of a pain not being able to do it with the Harmony Remote (hence using the motion sensor to ‘pre-arm’ the TV). Having both set up as options means I can tell Google Assistant to start it (using the SmartThings routine) while I’m out of the room, but also anyone in the room can pick up the remote and hit “Watch TV”
Example 2: Sodding TP-Link. Cheap, reasonable looking sockets, with power monitoring, that don’t integrate with IFTTT or SmartThings?! Grr… So my media server (Ubuntu Linux box) is now also running a small node.js script that SmartThings can talk to which switches the TP-Link sockets on and off. If I’d known, I would have spent the extra £5 on the WeMo ones.
Oh, on the subject of cameras, I haven’t got any at the moment, but if you open the SmartThings app and hit “Add a Thing” then “Add Device Manually” then “Cameras” it lists 10 or so that look like they’ll integrate directly. I’ve read good things about the D-Link Camera, for example. Others might know more.
The multi-sensor is a really fun bit of kit. I didn’t quite realise how versatile it was until it arrived! It’s currently being used to control my wife’s office lights (LIFX LED strip) using the Mood Cube SmartApp - flip it over and the lights change colour (proof of concept - will probably redo it in CoRE). Also the magnetic sensor in it (closed/open state) switches on the printer in my office (we both do some work from home, but the printer is upstairs and she’s usually downstairs). I’m wondering if I can use the accelerometer in it for something else as well - ie: pick it up and shake it to trigger an action.
My main reason for choosing SmartThings was this community - it seems like there are people really invested in this system, which is awesome. I get the feeling that if Samsung was to pull the plug tomorrow, everything would somehow be back up and running by next week!
I like the idea of the tumble dryer, in fact I wanted to do something similar myself with the washing machine, but I hadn’t found anything to handle the load requirement. I assume you are using the below, rated to 3kw?
The community is great here and if you know what you are doing I think the platform is very customisable… but if ST pulled the plug we would all be buggered, without the cloud this platform just doesn’t work, and not to forget that even includes if your internet stops working, nothing in your house will work either!! Just make sure you have a good and reliable broadband connection!
