No these are just basic motion switches not smart switches but I also use a similar brand of switch for my bathroom fans and they work great not really a need for an expensive smart switch for the bathroom fans.
A connected fan switch works great in conjunction with a humidity sensor to vent a steamy room. If you live in a rain forest like I do (Western Piedmont of the Blue Ridge Mts.) moisture control is a must.
I’ve had one of those humidity sensors for a few months and just got around to installing it my laundry room yesterday. It’s in the same box as a 3-way switch that I replaced with a Z-Wave switch and I couldn’t figure out the 3-way wiring until yesterday. I haven’t done laundry yet, so I haven’t used it except to turn it on, but I’m sure it’ll work well.
I’ve also replaced a couple of regular outlets with the TopGreener ones that include USB ports and they’ve worked flawlessly. Both installations were a little tough because the new outlets are larger and harder to squeeze in with all the wires, but I got them jammed in there eventually. I believe they were TU2154A. They charge my iPads and iPhones pretty quickly.
