To integrate diffuser type, which value should I use as categories?
I want to integrate diffuser(or air freshener) device type using ST schema.
But I’m not sure which value should I provide on devices[…].deviceContext.categories in Discovery response.
I could not find appropriate(or similar) value for diffuser(or air freshener) device type from a list of categories.
Should I use “Others” as categories value for now, or is there any other channel I could make a request to add support for diffuser(or air freshener) device type categories value?
Hi @blue9519 in this case only the icon of the device will be affected, the functionality must be based on the device profile, in the case that you want to certify the device you can add this situation to the processes.
I see, thank you!
