I’ve modified the “Rise and Shine” smart app to change modes during a specific time frame if motion is detected at a specified sensor. Here’s the problem: it will only fire once. I install the app, set the preferences and it works exactly as I want. But, once it fires the first time, it won’t do it again. I can change the mode back and activate the motion sensor, but the mode remains the same. I really don’t know what I’m doing, so I may have goofed the code. Please help! Here’s the code:
preferences {
section(“When there’s motion on this sensor”) {
input “motionSensors”, “capability.motionSensor”, multiple: false
section(“During this time window”) {
input “timeOfDay”, “time”, title: "Start Time?"
input “endTime”, “time”, title: “End Time?”, required: true
section(“Change to this mode”) {
input “newMode”, “mode”, title: “Mode?”
section(“And (optionally) turn on these appliances”) {
input “switches”, “capability.switch”, multiple: true, required: false
section( “Notifications” ) {
input “sendPushMessage”, “enum”, title: “Send a push notification?”, metadata:[values:[“Yes”,“No”]], required:false
input “phoneNumber”, “phone”, title: “Send a Text Message?”, required: false
def installed() {
log.debug "installed, current mode = ${location.mode}, state.actionTakenOn = ${state.actionTakenOn}"
initialize()
def updated() {
log.debug "updated, current mode = ${location.mode}, state.actionTakenOn = ${state.actionTakenOn}"
unsubscribe()
initialize()
def initialize() {
log.trace "timeOfDay: $timeOfDay, endTime: $endTime"
subscribe(motionSensors, “motion.active”, motionActiveHandler)
subscribe(location, modeChangeHandler)
if (state.modeStartTime == null) {
state.modeStartTime = 0
def modeChangeHandler(evt) {
state.modeStartTime = now()
def motionActiveHandler(evt)
// for backward compatibility
def t0 = now()
def modeStartTime = new Date(state.modeStartTime)
def timeZone = location.timeZone ?: timeZone(timeOfDay)
def startTime = timeTodayAfter(modeStartTime, timeOfDay, timeZone)
def endTime = timeTodayAfter(startTime, endTime ?: "24:00", timeZone)
log.debug "startTime: $startTime, endTime: $endTime, t0: ${new Date(t0)}, modeStartTime: ${modeStartTime}, actionTakenOn: $state.actionTakenOn, currentMode: $location.mode, newMode: $newMode "
if (t0 >= startTime.time && t0 <= endTime.time && location.mode != newMode) {
def message = "SmartThings changed the mode to '$newMode'"
send(message)
setLocationMode(newMode)
log.debug message
def dateString = new Date().format("yyyy-MM-dd")
log.debug "last turned on switches on ${state.actionTakenOn}, today is ${dateString}"
if (state.actionTakenOn != dateString) {
log.debug "turning on switches"
state.actionTakenOn = dateString
switches?.on()
else {
log.debug "not in time window, or mode is already set, currentMode = ${location.mode}, newMode = $newMode"
private send(msg) {
if ( sendPushMessage != “No” ) {
log.debug( “sending push message” )
sendPush( msg )
if ( phoneNumber ) {
log.debug( "sending text message" )
sendSms( phoneNumber, msg )
log.debug msg
