I bought a new ST smart power outlet a couple of days ago and set 3 simple automations in Classic using the Smart Lighting app (an on time and an off time for each automation).
All timers perform correctly.
However, in STSC two of the automations display correctly (when viewed in Smart Lighting), but one doesn’t display the times; the fields are blank.
I tried editing, deleting and recreating in STSC, but the time on and off fields just will not populate.
Yeah… I just tried and I’m able to edit one created in Classic in STSC, no problem. Change is reflected correctly in both. You might try removing that smartlights autoamtion and rebuilding it.
The time fields do not populate in STSC (but only in this automation; I have 2 other automations (on/off timers) for the same device which have populated).
Despite not showing in STSC, the timer fires correctly.
