Is there a reason why the Smart Lighting app has no ability to specify a time condition? I see this is possible in the Automations section but then I have to add a one second delay to motion based triggers.
Thanks,
->g.
Thanks,
->g.
what if you click on “More options” at the bottom of that screen? Choose Starting at a specific time, set the time below that selection… then the same for ending at a specific time.
yes… what @JDRoberts says below
It’s there, it’s just that in smart lighting first you specify the “that“ and then you specify the “if.“ But “specific time“ is one of the options for triggers.
I don’t have that option. If I select more options the only time related option I have is certain days of the week. And I can only select one trigger. If I select a motion sensor as my trigger and then go back and select at a specific time I lose the motion trigger.
Never mind I got it now. After seeing if I could have more than one trigger it saved my changes even though I hit cancel and discard. Once I selected my motion sensor as the trigger again the more options selections changed and I was able to set sunset/rise ranges.
