So, I’m reading through ask if this and I’m trying to find the trend. Which of course is impossible because I have incomplete data.
For everyone that is having all of these problems, there must be something, or multiple somethings, that is in common.
Are each of you using the harmony integration?
Is there are particular device, our virtual device, that you are using?
Are you using the new hue hub?
How many devices are connected via a third part hub? Hue? Harmony? Wink?
Are you using wifi based devices? Thermostats?
It could be any number of things.
But, I believe that the majority of individual here actually have faith in the system, even with the bugs, glitches, lack of timely support, etc… Or ST would not have been alive for this long.
I’ve personally only had two routines not fire for me. It was one time each. I’ve noticed a delay in a locally run app one time. Other than that, it’s ask run as designed.
I have GE switches, GE link bulbs, Wemo switches, hue v1 integration, echo integration, gd00z garage door control, Phillips bulbs, Leviton plug in dimmers and switches, iris contact sensors… I have only 4 custom apps installed. I have a couple of custom device types too.
I have about 8 routines running. About 15 smart lighting routines. I do not have misses changing, except at night to turn on security and in the morning to turn it off. I switch between home and night only.
Roughly 45 devices with about 5 virtual switches.
I’m not having the same problems.
Posting this kind of information, while knowing the company employees are actively viewing (maybe not responding) this forum will go a lot further toward improving our investments…n. Than calling them names and threatening to run away to the competition.
I step down from the soap box…
