Yep. It shows up. It worked for a while then it stopped after one of the firmware updates, I think.
When you go into the IDE list of smartapps (My Location --> List SmartApps) and click on the app youâre having a problem with, what does it say under the âScheduled Jobsâ section?
So itâs scheduled properly. Did the logs show anything happening for the previous run times listed?
when you look at the log for the bulb itself, does it get any command sent to it at all?
Interesting⊠donât see any command being sent to it from the app. Itâs a z-wave paddle switch, by the way, not a bulb, shouldnât make any difference I assumed. Itâs also supposed to turn on when Home Monitor detects an intrusion which works perfectly.
Are you using the Smart Lighting SmartApp to handle this or is it a custom SmartApp?
The Smart Lighting app from SmartThings.
And youâre just using a standard time trigger? (on at x time and off at y time)
Yes. 6 PM on 11 PM off, but only when itâs in Away mode.
Two questions then:
Do you have any other Smart Lighting automations based on times but NOT on mode that are working?
Have you been able to confirm that your mode is changing properly?
Same problem this AM as Kel has. A new rule (shutoff light at sunrise + 30) on V1 hub did not turn off the light. The Ide log shows this rule ran on time and scheduled it to run again tomorrow. The ârecentlyâ log for this device on my mobile app, however, does not contain any entry indicating shutoff was triggered.
Nope.
Yeah. I manually changed the mode and tested again just a few days ago.
Status page says there were some âservice degradationâ problems this morning for some users. So you mightâve also walked into that.
Yeah. Thatâs another issue⊠my hubâs been offline for 2 hours nowâŠ
Apparently ST pushed out an update and some hubs couldnât reconnect after rebootâŠ
Maybe un-select and re-select the lights that you want the rule to work on and then hit âdoneâ. It seems like itâs not properly associated with the device for some reason. Have you tried the online chat with support?
Iâve uninstalled and re-installed the Smart Lighting smartapp altogether. I was chatting with support earlier and they couldnât figure it out either. When I donât specify a mode, it works fine, so itâs something to do with that. I mean I could set it up to just turn on regardless of the mode, but I really donât need it to do that when Iâm home sitting in my living room.
I know local processing is a big selling point but have you considered looking into using Rule Machine while Smart Lighting continues to have this issue?
