TILT Hydrometer and Thermometer Integration
Hello, good afternoon, I do not know if it is correct to post here.
Maybe there is someone interested in the world of home brewing who wants to integrate this useful device.
There seems to be tools and code from the manufacturer to achieve integration.
Thank you all.
https://tilthydrometer.com
Designed for home brewing, the Tilt is a wireless hydrometer that lets you instantly read your brew’s specific gravity and temperature on your compatible Apple iPhone/iPad or Android smartphone/tablet or Tilt Pi. Most Bluetooth 4.0+ devices will work with the Tilt. You can then optionally save the data automatically to the cloud using our free Google Sheets template or other 3rd party cloud platforms. See our Apps section for more detail.
Our goal is to help homebrewers brew better beer. The Tilt hydrometer allows you to check the specific gravity and temperature of your beer while it’s fermenting, without ever having to open your fermenter or pour out any of your precious brew. This makes brewing more consistent and easy to track.
Here are some of the new features of the Tilt:
  • Range: Better reception and range. With the increased transmission power your Tilt will send data through larger, thicker-walled fermenters.
  • Precision: Upgraded sensors. With an improved temperature sensor and accelerometer your Tilt will operate with more precision.
  • Efficiency: We’ve reduced power consumption so more brews, less battery.
  • New Look: Newly designed custom circuit board and harness.
If using multiple Tilt Hydrometers for different batches of fermenting beer you must use a different color for each batch. The app will not read multiple hydrometers of the same color.
Each Tilt comes calibrated and ready to go with a pre-installed battery. Just download the free app, sanitize your Tilt, drop in your fermenter, and start taking readings with your phone, tablet, or Tilt Pi.
The specific gravity is accurate +/- 0.002 within the Tilt’s range of 0.990 to 1.120. The thermometer is accurate +/- 1 degree F (+/- 0.5 degree C).
http://www.ispindel.de/
# iSpindel - DIY electronic Hydrometer
