Grok got it working cross-platform (tested on Windows and Linux) without Bonjour, DNS-SD, etc., by using python-zeroconf, installed using pip install zeroconf.
matter-map-cross-platform-pip-zeroconf.py
#!/usr/bin/env python3
matter-map for cross-platform, tested on Windows and Linux.
Requires:
smartthings CLI in PATH
import ipaddress
import json
import sys
import time
from collections import defaultdict
from concurrent.futures import ThreadPoolExecutor, as_completed
from zeroconf import IPVersion, ServiceBrowser, Zeroconf
# ---------------- configuration ----------------
CACHE_TTL = 300 # seconds for hostname cache
MAX_THREADS = 10 # max parallel DNS resolution threads
BROWSE_TIMEOUT = 15 # max seconds to browse for _matter._tcp
BROWSE_QUIET = 2.5 # stop early once this long passes with no new service
# Matter operational ads (especially Thread) arrive on IPv6. Zeroconf's
# default is IPv4-only, which sees none of them on this network.
# ---------------- helpers ----------------
def run(cmd):
import subprocess
return subprocess.check_output(cmd, text=True, stderr=subprocess.DEVNULL)
def get_locations():
locations = json.loads(run(["smartthings", "locations", "-j"]))
id_to_name = {}
name_to_id = {}
for loc in locations:
id_to_name[loc["locationId"]] = loc["name"]
name_to_id[loc["name"]] = loc["locationId"]
return id_to_name, name_to_id
def get_matter_devices(location_id=None):
cmd = ["smartthings", "devices", "--type", "MATTER", "-j"]
if location_id:
cmd += ["--location", location_id]
devices = json.loads(run(cmd))
results = []
for d in devices:
network_id = d.get("matter", {}).get("networkId")
if not network_id:
continue
results.append({
"label": d.get("label", "UNKNOWN"),
"instance": network_id,
"locationId": d.get("locationId"),
"hostname": "", # will be filled by DNS
"ipv4": "",
"ipv6": "",
return results
# ---------------- mDNS via zeroconf (no Bonjour) ----------------
def _instance_from_service_name(name):
"""CC55...-DB25...._matter._tcp.local. -> CC55...-DB25..."""
suffix = "._matter._tcp.local."
if name.endswith(suffix):
return name[: -len(suffix)]
return name.split("._matter._tcp.")[0]
def _pick_addresses(addr_strings):
"""Choose one IPv4 and one IPv6, matching what dns-sd tends to surface.
Prefer a global IPv6 address, then a unique-local (Thread) address, then
link-local. info.addresses is often IPv4-only even when AAAA records were
received; callers should pass ServiceInfo.parsed_addresses().
ipv4 = ""
v6_global = []
v6_ula = []
v6_link = []
for raw in addr_strings:
try:
ip = ipaddress.ip_address(raw.split("%", 1)[0])
except ValueError:
continue
if ip.version == 4:
if not ipv4:
ipv4 = str(ip)
elif ip.is_link_local:
v6_link.append(ip)
elif ip.is_private:
v6_ula.append(ip)
else:
v6_global.append(ip)
chosen = (v6_global or v6_ula or v6_link or [None])[0]
ipv6 = chosen.compressed if chosen is not None else ""
return ipv4, ipv6
def get_dns_sd_data(debug_dns=False):
"""Discover _matter._tcp services using pure-Python zeroconf."""
data = defaultdict(dict)
names = []
last_add = time.time()
class Listener:
def add_service(self, zc, type_, name):
nonlocal last_add
if debug_dns:
print(f"[DEBUG] Found: {name}")
if name not in names:
names.append(name)
def remove_service(self, zc, type_, name):
pass
def update_service(self, zc, type_, name):
pass
# Do not resolve inside the listener: get_service_info takes the zeroconf
# lock and deadlocks if called from a ServiceBrowser callback.
# A fixed short sleep drops Thread devices when the first query is late.
zc = Zeroconf(ip_version=IPVersion.All)
browser = ServiceBrowser(zc, "_matter._tcp.local.", Listener())
if debug_dns:
print(f"[DEBUG] Browsing _matter._tcp for up to {BROWSE_TIMEOUT}s...")
started = time.time()
while time.time() - started < BROWSE_TIMEOUT:
time.sleep(0.25)
if names and time.time() - last_add >= BROWSE_QUIET:
break
if debug_dns:
print(f"[DEBUG] Browse saw {len(names)} services")
for name in names:
info = zc.get_service_info("_matter._tcp.local.", name, timeout=3000)
if not info:
if debug_dns:
print(f"[DEBUG] No service info for {name}")
continue
instance = _instance_from_service_name(name)
hostname = info.server.rstrip(".") if info.server else ""
data[instance]["hostname"] = hostname
ipv4, ipv6 = _pick_addresses(info.parsed_addresses())
if ipv4:
data[instance]["ipv4"] = ipv4
if ipv6:
data[instance]["ipv6"] = ipv6
if debug_dns:
print(f"[DEBUG] {instance} {hostname} {ipv6} {ipv4}")
browser.cancel()
zc.close()
return data
# ---------------- hostname cache (kept for compatibility) ----------------
hostname_cache = {} # hostname -> (ipv4, ipv6, timestamp)
def resolve_hostname_cached(hostname, debug_dns=False):
"""Fallback resolution if zeroconf didn't already give addresses.
On modern Windows the native resolver often works for .local names
without Bonjour, so we try it first.
now = time.time()
if hostname in hostname_cache:
ipv4, ipv6, ts = hostname_cache[hostname]
if now - ts < CACHE_TTL:
return ipv4, ipv6 # use cached
ipv4, ipv6 = "", ""
try:
import socket
# getaddrinfo works for .local on Windows 10 1703+ without Bonjour
results = socket.getaddrinfo(hostname, None, socket.AF_UNSPEC, socket.SOCK_STREAM)
for res in results:
family, _, _, _, sockaddr = res
ip = sockaddr[0]
if family == socket.AF_INET and not ipv4:
ipv4 = ip
elif family == socket.AF_INET6 and not ipv6:
# skip link-local scope id if present
ipv6 = ip.split("%")[0]
except Exception as e:
if debug_dns:
print(f"[DEBUG] getaddrinfo failed for {hostname}: {e}")
hostname_cache[hostname] = (ipv4, ipv6, now)
return ipv4, ipv6
# ---------------- help ----------------
def print_help():
print("""Usage: matter-map [LOCATION] [OPTIONS]
Positional arguments:
LOCATION Filter devices by location name
Options:
--help Show this help message and exit
--sort=FIELD Sort by field: label, location, instance, hostname, ipv4, ipv6
--reverse Reverse sort order
--debug-dns Print debug info for mDNS queries""")
# ---------------- main ----------------
def main():
sort_key = "label"
reverse = False
location_arg = None
debug_dns = False
args = sys.argv[1:]
positional_args = []
for arg in args:
if arg == "--help":
print_help()
sys.exit(0)
elif arg == "--reverse":
reverse = True
elif arg == "--debug-dns":
debug_dns = True
elif arg.startswith("--sort="):
sort_key = arg.split("=", 1)[1]
elif arg.startswith("-"):
print(f"Unknown option: {arg}", file=sys.stderr)
sys.exit(1)
else:
positional_args.append(arg)
if len(positional_args) > 1:
print("Error: only one location name may be specified", file=sys.stderr)
sys.exit(1)
if positional_args:
location_arg = positional_args[0]
valid_sorts = {"label", "location", "instance", "hostname", "ipv4", "ipv6"}
if sort_key not in valid_sorts:
print(f"Invalid sort key: {sort_key}", file=sys.stderr)
print(f"Valid options: {', '.join(sorted(valid_sorts))}", file=sys.stderr)
sys.exit(1)
id_to_name, name_to_id = get_locations()
location_id = None
if location_arg:
location_id = name_to_id.get(location_arg)
if not location_id:
print("Unknown location", file=sys.stderr)
sys.exit(1)
devices = get_matter_devices(location_id)
dns_data = get_dns_sd_data(debug_dns)
# Merge DNS-SD data into devices
for d in devices:
dns = dns_data.get(d["instance"], {})
d["hostname"] = dns.get("hostname", "UNKNOWN")
d["ipv4"] = dns.get("ipv4", "")
d["ipv6"] = dns.get("ipv6", "")
d["location"] = id_to_name.get(d.get("locationId"), "UNKNOWN")
# Resolve hostnames that mDNS did not already give an address for.
# Windows getaddrinfo can answer .local without Bonjour, but it is slower
# and often returns a different address than the Matter SRV record.
to_resolve = [
d for d in devices
if d["hostname"] not in ("", "UNKNOWN") and not (d["ipv4"] or d["ipv6"])
with ThreadPoolExecutor(max_workers=MAX_THREADS) as executor:
future_to_device = {
executor.submit(resolve_hostname_cached, d["hostname"], debug_dns): d
for d in to_resolve
for future in as_completed(future_to_device):
d = future_to_device[future]
try:
ipv4, ipv6 = future.result()
d["ipv4"] = ipv4 or d["ipv4"]
d["ipv6"] = ipv6 or d["ipv6"]
except Exception:
pass
# Sort and group
devices.sort(key=lambda r: r.get(sort_key, ""), reverse=reverse)
grouped = defaultdict(list)
for r in devices:
grouped[r.get("location", "UNKNOWN")].append(r)
# Print output (same format as original)
print(
f"{'DEVICE LABEL':<25} {'LOCATION':<15} {'INSTANCE NAME/NETWORK ID':<40} "
f"{'HOSTNAME':<30} {'IPv6 ADDRESS':<40} {'IPv4 ADDRESS':<20}"
print("-" * 180)
for location in sorted(grouped):
for r in grouped[location]:
print(
f"{r['label']:<25} "
f"{location:<15} "
f"{r['instance']:<40} "
f"{r['hostname']:<30} "
f"{r['ipv6']:<40} "
f"{r['ipv4']:<20}"
if __name__ == "__main__":
main()
matter-map-windows-built-in.py
matter-map for Windows — native DNS-SD via ctypes (no Bonjour, no extra packages).
Uses DnsServiceBrowse / DnsServiceResolve from dnsapi.dll.
Browse answers often include SRV, A, and AAAA records for Wi-Fi devices.
Thread devices frequently arrive as PTR only, so those are resolved separately.
Requires Windows 10 1703+ / Windows 11 and the smartthings CLI in PATH.
import ctypes
import ipaddress
import json
import socket
import sys
import threading
import time
from ctypes import wintypes
# ---------------- Windows DNS-SD bindings ----------------
dnsapi = ctypes.WinDLL("dnsapi")
DNS_QUERY_REQUEST_VERSION1 = 1
DNS_REQUEST_PENDING = 9506
ERROR_CANCELLED = 1223
DNS_TYPE_A = 1
DNS_TYPE_PTR = 12
DNS_TYPE_AAAA = 28
DNS_TYPE_SRV = 33
class DNS_SERVICE_CANCEL(ctypes.Structure):
_fields_ = [("reserved", ctypes.c_void_p)]
class DNS_SERVICE_BROWSE_REQUEST(ctypes.Structure):
_fields_ = [
("Version", wintypes.ULONG),
("InterfaceIndex", wintypes.ULONG),
("QueryName", wintypes.LPCWSTR),
("pBrowseCallback", ctypes.c_void_p),
("pQueryContext", ctypes.c_void_p),
class DNS_SERVICE_RESOLVE_REQUEST(ctypes.Structure):
_fields_ = [
("QueryName", wintypes.LPWSTR),
("pResolveCompletionCallback", ctypes.c_void_p),
class DNS_SERVICE_INSTANCE(ctypes.Structure):
_fields_ = [
("pszInstanceName", wintypes.LPWSTR),
("pszHostName", wintypes.LPWSTR),
("ip4Address", ctypes.POINTER(wintypes.DWORD)),
("ip6Address", ctypes.POINTER(ctypes.c_ubyte * 16)),
("wPort", wintypes.WORD),
("wPriority", wintypes.WORD),
("wWeight", wintypes.WORD),
("dwPropertyCount", wintypes.DWORD),
("keys", ctypes.POINTER(wintypes.LPWSTR)),
("values", ctypes.POINTER(wintypes.LPWSTR)),
("dwInterfaceIndex", wintypes.DWORD),
class DNS_RECORD(ctypes.Structure):
pass
# Fixed header is 32 bytes on 64-bit Windows. The Data union starts there.
# pData aliases the first pointer of PTR (pNameHost) and SRV (pNameTarget).
DNS_RECORD._fields_ = [
("pNext", ctypes.POINTER(DNS_RECORD)),
("pName", wintypes.LPWSTR),
("wType", wintypes.WORD),
("wDataLength", wintypes.WORD),
("Flags", wintypes.DWORD),
("dwTtl", wintypes.DWORD),
("dwReserved", wintypes.DWORD),
("pData", wintypes.LPWSTR),
BROWSE_CALLBACK = ctypes.WINFUNCTYPE(
None, wintypes.DWORD, ctypes.c_void_p, ctypes.POINTER(DNS_RECORD)
RESOLVE_CALLBACK = ctypes.WINFUNCTYPE(
None, wintypes.DWORD, ctypes.c_void_p, ctypes.POINTER(DNS_SERVICE_INSTANCE)
dnsapi.DnsServiceBrowse.argtypes = [
ctypes.POINTER(DNS_SERVICE_BROWSE_REQUEST),
ctypes.POINTER(DNS_SERVICE_CANCEL),
dnsapi.DnsServiceBrowse.restype = wintypes.DWORD
dnsapi.DnsServiceBrowseCancel.argtypes = [ctypes.POINTER(DNS_SERVICE_CANCEL)]
dnsapi.DnsServiceBrowseCancel.restype = wintypes.DWORD
dnsapi.DnsServiceResolve.argtypes = [
ctypes.POINTER(DNS_SERVICE_RESOLVE_REQUEST),
dnsapi.DnsServiceResolve.restype = wintypes.DWORD
dnsapi.DnsServiceResolveCancel.argtypes = [ctypes.POINTER(DNS_SERVICE_CANCEL)]
dnsapi.DnsServiceResolveCancel.restype = wintypes.DWORD
dnsapi.DnsServiceFreeInstance.argtypes = [ctypes.POINTER(DNS_SERVICE_INSTANCE)]
dnsapi.DnsServiceFreeInstance.restype = None
CACHE_TTL = 300
MAX_THREADS = 10
BROWSE_TIMEOUT = 15
BROWSE_QUIET = 2.5
RESOLVE_TIMEOUT = 8
def run(cmd):
import subprocess
id_to_name = {}
name_to_id = {}
if location_id:
results = []
for d in devices:
if not network_id:
continue
results.append({
"hostname": "",
"ipv4": "",
"ipv6": "",
return results
suffix = "._matter._tcp.local"
lower = name.lower()
idx = lower.find(suffix)
if idx >= 0:
return name[:idx]
def _record_data(record, size):
return ctypes.string_at(ctypes.addressof(record) + 32, size)
"""Prefer a global IPv6 address, then unique-local, then link-local."""
ipv4 = ""
v6_global = []
v6_ula = []
v6_link = []
try:
ip = ipaddress.ip_address(str(raw).split("%", 1)[0])
except ValueError:
continue
if ip.version == 4:
if not ipv4:
ipv4 = str(ip)
v6_link.append(ip)
elif ip.is_private:
v6_ula.append(ip)
else:
ipv6 = chosen.exploded.upper() if chosen is not None else ""
return ipv4, ipv6
def _format_ipv6(text):
if not text:
return ""
try:
return ipaddress.IPv6Address(text.split("%", 1)[0]).exploded.upper()
except ValueError:
return text
# ---------------- native DNS-SD discovery ----------------
class _ContextBox(ctypes.Structure):
_fields_ = [("obj", ctypes.py_object)]
def _context_from_ptr(context_ptr):
if not context_ptr:
return None
return ctypes.cast(context_ptr, ctypes.POINTER(_ContextBox)).contents.obj
class DiscoveryContext:
def __init__(self):
self.services = {} # instance -> {"hostname", "ipv4": set, "ipv6": set}
self.lock = threading.Lock()
self.last_add = time.time()
self.resolve_done = threading.Event()
self.pending_resolves = 0
def _service(ctx, instance):
entry = ctx.services.get(instance)
if entry is None:
entry = {"hostname": "", "ipv4": set(), "ipv6": set()}
ctx.services[instance] = entry
ctx.last_add = time.time()
return entry
def browse_callback(status, context_ptr, record):
if status not in (0, ERROR_CANCELLED) or not record or not context_ptr:
return
ctx = _context_from_ptr(context_ptr)
if ctx is None:
return
rec = record
current = None
try:
while rec:
item = rec.contents
if item.wType == DNS_TYPE_PTR and item.pData:
current = _instance_from_service_name(ctypes.wstring_at(item.pData))
with ctx.lock:
_service(ctx, current)
elif current and item.wType == DNS_TYPE_SRV and item.pData:
hostname = ctypes.wstring_at(item.pData).rstrip(".")
with ctx.lock:
entry = _service(ctx, current)
if hostname:
entry["hostname"] = hostname
elif current and item.wType == DNS_TYPE_A and item.wDataLength >= 4:
ipv4 = socket.inet_ntoa(_record_data(item, 4))
with ctx.lock:
_service(ctx, current)["ipv4"].add(ipv4)
elif current and item.wType == DNS_TYPE_AAAA and item.wDataLength >= 16:
ipv6 = socket.inet_ntop(socket.AF_INET6, _record_data(item, 16))
with ctx.lock:
_service(ctx, current)["ipv6"].add(ipv6)
rec = item.pNext
except Exception:
return
def resolve_callback(status, context_ptr, instance_ptr):
try:
if status == 0 and instance_ptr and ctx is not None:
inst = instance_ptr.contents
full_name = inst.pszInstanceName or ""
instance = _instance_from_service_name(full_name) if full_name else ""
hostname = (inst.pszHostName or "").rstrip(".")
ipv4 = ""
ipv6 = ""
if inst.ip4Address:
raw = inst.ip4Address.contents
ipv4 = socket.inet_ntoa(raw.to_bytes(4, "little"))
if inst.ip6Address:
ipv6 = socket.inet_ntop(socket.AF_INET6, bytes(inst.ip6Address.contents))
if instance:
with ctx.lock:
entry = _service(ctx, instance)
if hostname:
if ipv4:
entry["ipv4"].add(ipv4)
if ipv6:
entry["ipv6"].add(ipv6)
except Exception:
pass
finally:
if instance_ptr:
dnsapi.DnsServiceFreeInstance(instance_ptr)
if ctx is not None:
with ctx.lock:
ctx.pending_resolves -= 1
if ctx.pending_resolves <= 0:
ctx.resolve_done.set()
"""Discover _matter._tcp services using dnsapi.dll."""
ctx = DiscoveryContext()
# py_object plus an explicit keepalive. The browse request only stores the address.
ctx_obj = _ContextBox(ctx)
ctx_ref = ctypes.pointer(ctx_obj)
ctx_ptr = ctypes.cast(ctx_ref, ctypes.c_void_p)
browse_cb = BROWSE_CALLBACK(browse_callback)
resolve_cb = RESOLVE_CALLBACK(resolve_callback)
query = ctypes.create_unicode_buffer("_matter._tcp.local")
req = DNS_SERVICE_BROWSE_REQUEST()
req.Version = DNS_QUERY_REQUEST_VERSION1
req.InterfaceIndex = 0
req.QueryName = ctypes.cast(query, wintypes.LPCWSTR)
req.pBrowseCallback = ctypes.cast(browse_cb, ctypes.c_void_p)
req.pQueryContext = ctx_ptr
cancel = DNS_SERVICE_CANCEL()
status = dnsapi.DnsServiceBrowse(ctypes.byref(req), ctypes.byref(cancel))
if status not in (0, DNS_REQUEST_PENDING):
print(f"DnsServiceBrowse failed: {status}", file=sys.stderr)
return {}
if debug_dns:
print(f"[DEBUG] Browsing _matter._tcp for up to {BROWSE_TIMEOUT}s...", flush=True)
time.sleep(0.25)
with ctx.lock:
count = len(ctx.services)
last_add = ctx.last_add
if count and time.time() - last_add >= BROWSE_QUIET:
break
dnsapi.DnsServiceBrowseCancel(ctypes.byref(cancel))
with ctx.lock:
missing = [name for name, entry in ctx.services.items() if not entry["hostname"]]
if debug_dns:
print(f"[DEBUG] Browse saw {len(ctx.services)} services, resolving {len(missing)}", flush=True)
resolve_names = []
resolve_requests = []
resolve_cancels = []
if missing:
with ctx.lock:
ctx.pending_resolves = len(missing)
ctx.resolve_done.clear()
for instance in missing:
buf = ctypes.create_unicode_buffer(f"{instance}._matter._tcp.local")
rreq = DNS_SERVICE_RESOLVE_REQUEST()
rreq.Version = DNS_QUERY_REQUEST_VERSION1
rreq.InterfaceIndex = 0
rreq.QueryName = ctypes.cast(buf, wintypes.LPWSTR)
rreq.pResolveCompletionCallback = ctypes.cast(resolve_cb, ctypes.c_void_p)
rreq.pQueryContext = ctx_ptr
rcancel = DNS_SERVICE_CANCEL()
rc = dnsapi.DnsServiceResolve(ctypes.byref(rreq), ctypes.byref(rcancel))
if rc not in (0, DNS_REQUEST_PENDING):
with ctx.lock:
if debug_dns:
print(f"[DEBUG] DnsServiceResolve failed for {instance}: {rc}", flush=True)
continue
resolve_names.append(buf)
resolve_requests.append(rreq)
resolve_cancels.append(rcancel)
with ctx.lock:
ctx.resolve_done.wait(RESOLVE_TIMEOUT)
for rcancel in resolve_cancels:
dnsapi.DnsServiceResolveCancel(ctypes.byref(rcancel))
# Keep callback and request objects alive until the cancels above have run.
_keepalive = (browse_cb, resolve_cb, ctx_obj, ctx_ref, query, req, resolve_names, resolve_requests)
data = {}
with ctx.lock:
items = list(ctx.services.items())
for instance, entry in items:
ipv4, ipv6 = _pick_addresses(list(entry["ipv4"]) + list(entry["ipv6"]))
data[instance] = {
"hostname": entry["hostname"],
"ipv4": ipv4,
"ipv6": ipv6,
if debug_dns:
print(f"[DEBUG] {instance} {entry['hostname']} {ipv6} {ipv4}", flush=True)
return data
# ---------------- hostname cache ----------------
hostname_cache = {}
now = time.time()
return ipv4, ipv6
ipv4, ipv6 = "", ""
try:
for res in results:
ip = sockaddr[0]
ipv4 = ip
ipv6 = _format_ipv6(ip)
if debug_dns:
return ipv4, ipv6
def print_help():
Options:
--debug-dns Print debug info for DNS-SD queries""")
def main():
sort_key = "label"
reverse = False
location_arg = None
debug_dns = False
args = sys.argv[1:]
for arg in args:
if arg == "--help":
print_help()
sys.exit(0)
reverse = True
debug_dns = True
sys.exit(1)
else:
sys.exit(1)
if positional_args:
sys.exit(1)
location_id = None
if location_arg:
if not location_id:
sys.exit(1)
for d in devices:
d["hostname"] = dns.get("hostname", "UNKNOWN") or "UNKNOWN"
to_resolve = [
d for d in devices
for d in to_resolve
try:
except Exception:
pass
for r in devices:
print(
print("-" * 180)
print(
f"{location:<15} "
f"{r['ipv6']:<40} "
f"{r['ipv4']:<20}"
main()
