@bridaus, no problem! It does take about 20 -30 minutes to setup correctly, but once you have it set it’s good to go. Also, the steps are pretty repetitive so once you get the hang of my logic it goes by pretty fast. Here are the steps:
- Go into the screen where you add/remove/rename your modes
1a) Change Home to Home Day
1b) Change Away to Away Day
1c) Remove Night
1d) Add a new mode called Home Night
1e) Add a new mode called Away Night
Now you should have all four modes: Home - Day, Home - Night, Away - Day, Away - Night.
- Go into Hello, Home
2a) Create a new Action called Come Home Day. Under “What do you want to happen?” set “Change the mode to” Home Day. Under “Additional settings” set “Automatically perform “Come Home Day” when…” to occur when Someone arrives. Under “Additional settings” in this same section check the boxes under “Don’t automatically do this if I am in one of these modes” for Home Day, Home Night, and Away Night.
2b) Create a new Action called Come Home Night. Under “What do you want to happen?” set “Change the mode to” Home Night. Under “Additional settings” set “Automatically perform “Come Home Night” when…” to occur when Someone arrives. Under “Additional settings” in this same section check the boxes under “Don’t automatically do this if I am in one of these modes” for Home Day, Home Night, and Away Day.
2c) Create a new Action called Leave Home Day. Under “What do you want to happen?” set “Change the mode to” Away Day. Under “Additional settings” set “Automatically perform “Leave Home Day” when…” to occur when Everyone leaves. Under “Additional settings” in this same section check the boxes under “Don’t automatically do this if I am in one of these modes” for Home Night, Away Day, and Away Night.
2d) Create a new Action called Leave Home Night. Under “What do you want to happen?” set “Change the mode to” Away Night. Under “Additional settings” set “Automatically perform “Leave Home Night” when…” to occur when Everyone leaves. Under “Additional settings” in this same section check the boxes under “Don’t automatically do this if I am in one of these modes” for Home Day, Away Day, and Away Night.
2e) Create a new Action called Sunrise Home. Under “What do you want to happen?” set “Change the mode to” Home Day. Under “Additional settings” set “Automatically perform “Sunrise Home” when…” to occur at Sunrise. Under “Additional settings” in this same section check the boxes under “Don’t automatically do this if I am in one of these modes” for Home Day, Away Day, and Away Night.
2f) Create a new Action called Sunrise Away. Under “What do you want to happen?” set “Change the mode to” Away Day. Under “Additional settings” set “Automatically perform “Sunrise Away” when…” to occur at Sunrise. Under “Additional settings” in this same section check the boxes under “Don’t automatically do this if I am in one of these modes” for Home Day, Home Night, and Away Day.
2g) Create a new Action called Sunset Home. Under “What do you want to happen?” set “Change the mode to” Home Night. Under “Additional settings” set “Automatically perform “Sunset Home” when…” to occur at Sunset. Under “Additional settings” in this same section check the boxes under “Don’t automatically do this if I am in one of these modes” for Home Night, Away Day, and Away Night.
2h) Create a new Action called Sunset Away. Under “What do you want to happen?” set “Change the mode to” Away Night. Under “Additional settings” set “Automatically perform “Sunset Away” when…” to occur at Sunset. Under “Additional settings” in this same section check the boxes under “Don’t automatically do this if I am in one of these modes” for Home Day, Home Night, and Away Night.
That’s it! Your four modes should begin switching automatically now based on presence and whether it’s day or night. Now just be sure to go into any of your lights, door locks, etc. that you have programmed to turn on/off, lock/unlock, etc. and select which of the four modes you want the actions to occur under.
Let me know of any questions.
