ThirdReality Garage Door Opener
Has anyone successfully been able to use this device? All I get is an on-off matter switch and no integration with the tilt switch..
You may want to read these Amazon reviews (particularly the second and third review) of this device to better understand how this device is designed to work. All you get is an on-off switch regardless of what platform you use to onboard the device. The tilt sensor is designed to automatically pair only with the door opener to relay its on-off status to the door opener and does not expose itself as an entity that can be used in any platform’s automation system.
