@pmjoen I have been testing the latest code on both of my 560s.
Every time I look for the device status in SmartThings the device is in “Checking” status. When I click the REFRESH arrow it reports the status. I am not sure if its normal or not but it appears the Roomba goes offline and stays offline.
When i try to clean it makes a few beeps then appears to go offline. I can usually get it to start by hitting clean three or four times but its very hit or miss and very hard to automate.
Hopefully you have some insight on what may be the issue for me.
Here are the logs. This error message appears: 1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:39 AM: error java.lang.NullPointerException: Cannot get property ‘cleaner_state’ on null object @ line 128
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:49 AM: debug Clean state st_off status 0
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:49 AM: info Firmware Version 1.0.94-310C-FCC
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:49 AM: info Model Number 500
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:49 AM: debug Main brush 0 and side brush 0
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:49 AM: debug Bin status value 0
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:49 AM: debug {
“action”:“full_status”,
“result”:“success”,
“firmware” : {
“version” : “1.0.94-310C-FCC”,
“wifi_version” : “310C”,
“uuid” : “66af1f53c67c089f”,
“mac_address”:“00:1E:C0:xx:xx:xx”,
“DHCP” : 1,
“has_been_backed_up” : 1,
“has_auth_token” : 1,
“boot_status” : “run success”,
“boot_version” : 5,
“auto_update” : 0,
“auto_dock” : 0,
“restart_AC” : 0,
“always_MAX” : 1,
“dock_at” : 25,
“stop_at” : 6,
“time_h_m” : “16:45”,
“selected_timezone” : “Africa/Abidjan”
“tc_status” : {
“name” : “Downstairs-Roomba”,
“modelnr” : “500”,
“tc-roomba-conn” : 0,
“cleaning_time” : “0”,
“cleaning_time_total” : “2742”,
“cleaning_distance” : “49356”,
“cleaning_distance_miles” : “30436”,
“dirt_detected” : 0,
“bin_status” : 0,
“server_connection” : 10,
“vacuum_drive” : 0,
“clean_delay” : 232,
"…[TRUNCATED]
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:38 AM: debug The Refresh Status Command was sent
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:38 AM: debug Network is not connected
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:38 AM: debug The Clean Command was sent
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:38 AM: debug Clean mode vlaue is Clean
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:38 AM: debug Clean mode is Clean
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:38 AM: debug Executing 'on’
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:39 AM: debug Device Network ID Set
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:39 AM: debug The Refresh Status Command was sent
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:38 AM: debug Executing 'poll’
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:38 AM: info Thinking Cleaner Version 2.2 Copyright © 2016 pmjoen
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:45:38 AM: debug Updated with settings: [ip:192.168.1.114, port:80, cleanmode:Clean, debug_pref:true, debug_ext:true]
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:42:39 AM: debug Bin status value 0
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:42:39 AM: debug Main brush 0 and side brush 0
1f6d7534-04a0-4bbe-a071-3de782bc0a33 11:42:39 AM: debug {
“result”:“success”,
“firmware” : {
“DHCP” : 1,
“boot_version” : 5,
“auto_update” : 0,
“auto_dock” : 0,
“restart_AC” : 0,
“always_MAX” : 1,
“dock_at” : 25,
“stop_at” : 6,
“time_h_m” : “16:42”,
“tc_status” : {
“modelnr” : “500”,
“tc-roomba-conn” : 1,
“bin_status” : 0,
“server_connection” : 0,
“vacuum_drive” : 0,
"clean…[TRUNCATED]
