Based on the fact that there’s still a bug in the “Things Quiet Down” code, I decided to write my own. It really only took 20 lines of code. Instead of trying to find x minutes of time with no activity at all during that time, I chose a simpler route. When no activity is first detected, it starts a delay timer (let’s use 15 minutes for this example). In 15 minutes, it then checks to see if there’s been recent activity or inactivity. If inactivity, it turns the lights off. If there was recent activity, it does nothing and the whole process starts over. If you happen to be in the room sitting still at the 15 minute mark, then all you have to do is move your hand and it comes back on immediately.
If I decide to get fancy, I may try to disable the “runOnce” each time activity is detected, thus making it a true inactivity period. I’ve seen comments that the “unscheduled()” function can take a long time to work, so I’m hesitant to spend time on that since it’s working pretty well.
Hopefully this code will help someone else… (I can’t seem to get the code to stay in one block below, but just put all the pieces together into one block of code.)
* Motion-controlled Lights
* Turn on lights when motion detected and turns off lights after x minutes without movement.
* Similar to "When quiet" but without the bugs
* Copyright 2015 Alan Buckner
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
namespace: “TexasFlyer”,
author: “Alan Buckner”,
description: “Turn on lights when motion detected and turns off lights after x minutes without movement. Similar to ‘When quiet’ but without the bugs”,
category: “My Apps”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png”,
iconX3Url: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png”)
preferences {
section {
input(name: "motion", type: "capability.motionSensor", title: "Pick your motion sensor", description: null, multiple: false, required: true, submitOnChange: true)
input(name: "dimmer", type: "capability.switchLevel", title: "Pick your dimming lamp(s)", description: null, multiple: false, required: true, ubmitOnChange: true)
input(name: "dimmerValue", type: "number", title: "Enter dimmer level percentage (no % sign)", required: true, submitOnChange: true)
input(name: "delayValue", type: "number", title: "Delay (in minutes) before turning off lights", required: true, submitOnChange: true)
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
//unsubscribe()
//unschedule() //Added based on another program. Not sure if needed.
initialize()
def initialize() {
subscribe(motion, “motion”, myMotionHandler)
dimmer.setLevel(0) // Easier to debug when you know that motion turns on the lights
sendNotificationEvent(“Motion-controlled lights is initializing…”)
state.TurnoffHandlerCalled = false
def myMotionHandler(evt) {
if("active" == evt.value) {
sendNotificationEvent("Motion detected - turning lights turned on")
dimmer.setLevel(settings.dimmerValue)
state.isActive = true
} else if("inactive" == evt.value) {
log.debug("Inactivity detected. TurnoffHandlerCalled = ${state.TurnoffHandlerCalled}")
state.isActive = false
if (state.TurnoffHandlerCalled == false) {
sendNotificationEvent(“Calling handlerTurnoff in ${settings.delayValue} minutes.”)
def delaySeconds = settings.delayValue * 60
runIn(delaySeconds, handlerTurnoff) //in seconds
state.TurnoffHandlerCalled = true //Avoids calling the handler over and over again
def handlerTurnoff() {
// Check to see if Motion was recently active or not. Avoids turning off the lamp right after an Active event
// which then requires a period of inactivity and then activity to make the light come back on
if (state.isActive == false) {
dimmer.setLevel(0)
sendNotificationEvent(“handlerTurnoff just turn off the motion lamps due to no recent activity”)
} else {
sendNotificationEvent(“handlerTurnoff just left the lamp on due to recent activity”)
