I can not open the locations tab. I have tried on a server I setup and your hosted server. Could it be something in my ST account?
You should get a drop down. Add your first location. I have checked it on the live server and my testing server.
Tried on 2 different computers with IE and Chrome. Both clicking on Locations and hovering over it. Nothing happens. It adds a â#â sign to the end of the web address it is currently on. âhttps://thinglayer.net/dashboard/indexâ to âhttps://thinglayer.net/dashboard/index#â
Looks like you have found a bug. I will fix this tonight.
Awesome!
Have you tried the grovestreams setup? Do you know the differences?
I have tried GroveStreams and I think they offer a great service. They have a great sensor monitoring solution that is fairly easy to set up. ThingLayer has been designed around the home with control, monitoring, and data analysis in mind.
Iâm currently running GroveStreams and itâs kind of bland. Any word on that update to fix locations?
I signed up⊠imported all my devices
I see nothing on the dashboardâŠ
Not sure what i did wrongâŠ
@MikeDL @BatraD Sorry for the delay. I have been moving all of my equipment. I have fixed the locations bug that was preventing new users from being able to add locations.
@BatraD The first step is to add a new location. Once you have a location, you can start assigning devices via the things page.
@jodyalbritton Jody ⊠Thanks. i added a new location, i still cant assign things to a Zone
i donât see any zone in the drop down when i click on an item under Things and canât see anything on the Dashboard⊠âŠ
@BatraD You add zones to the location you created. In the sidebar, Click locations, then the location you just created. You need to create a few zones. Then the box will be populated on the things page.
@jodyalbritton - -Thanks⊠I was thinking Locations are zones and never created a Zone under locationâŠ
Things now show up on the dashboard
Quick ? Why do dimmers show up both as a switch and a dimmer ?
Thanks for your help
Each function is treated as its own device. You can deselect the visible on dashboard box if you donât want the switch to be visible.
I signed up but my dashboard is empty even after authorizing my devices. Is there a step that I missed?
Create a location then create some zones. Assign your things to zones.
I have a lot of changes on my testing server. Some of them would have been breaking changes so I have been trying do the migration in a way that preserves historical data. The original setup I had with firebase was becoming untenable for the hosted version at ThingLayer.net. There are over 100 new features coming in the next iteration. This is just prep work for that. I should have it fully migrated by July 15th, so thatâs when I would start the docker work. Feel free to ask any questions or make suggestions.
Thanks for your help.
I looked through the updated website (thinglayer), and the old data is missing (at least for my instance). I havenât had a chance to reimport the data from STâŠbut I am assuming that could work?
On the docker front, I am working on building out the containers now. I am using Ubuntu 14.04, since your instructions were for Ubuntu; it just makes everythingâŠeasier. Iâm building two; one for your ruby environment and application, one for the MYSQL environment, and then I will link them on the Docker backend to prevent unnecessary port or security exposure. Iâm also building them from scratch because even the default containers from Ubuntu needed to be upgraded, and many of the containers on Docker Registry Hub have nasty vulnerabilities like heartbleed, etc. Thatâs all we need is for someone to get ripped up from the inside out! Not on my watchâŠ(Iâm a security guy by trade). Once theyâre built, tagged etcâŠI will put them on Dockerâs Registry Hub for you to instruct folks on grabbing them. I also have a massive backlog of containers I should put upâŠI just havenât had the time.
More to come soonâŠsorry itâs been taking longer than expected, but my regular job consumes a lot of my time!
