When I look at my history, it shows me the dates and times that I have run, but the gallons all show zero. Do I need additional equipment to monitor gallons?
This community is for SmartThings users, so just verifying you have a SmartThings hub, right?
If so, what device are you using in SmartThings that shows you gallons? The FortrezZ water meter?
More info is needed about your set up and the device.
I simply have the b-hyve Wi-Fi system controlling my irrigation lines.
Ah, ok. There may be some community members with the same system that may be able to help, but your best bet would be to reach out to their help center here : https://www.orbitonline.com/collections/b-hyve (scroll to the bottom where you’ll see Help Center)
