Thanks for the clarification!
Strangely, I have several Iris contact sensors but only one migrated. Go figure.
I have close to 40 iris contact sensors or may be more, all got migrated last nigh when my hub was down for 23 minutes. Interestingly this afternoon my hub was down for 6 minutes but nothing got migrated
Just realized I have a v3 hub and it has not been updated to show matter with the zwave and zigbee icons when I click on the hub in the app. Should v3 show this? There have been so many posts, I canāt remember where Iāve seen this info.
What type of phone are you using? iOS?
The bottom of the Hub page in the app will show the matter logo once you scroll to the bottom.
Not sure if the Matter logo shows on iOS devices yet.
Itās interesting. I have a v3 hub running beta firmware 45.01 with 99% of my devices on Edge drivers. My Android phone ST app shows a Matter logo, my iPad ST app does not show the Matter logo. Iām not sure why there is a discrepancy.
Due to the iOS app at this point.
Yep, iOS. Thanks for the info.
Which line in a device handler is its fingerprint? I am using an Aeotec multisensor 6 as the key to a lot of my automations. I think this line is the fingerprint for the deviceā¦
fingerprint deviceId: ā0x2101ā, inClusters: ā0x5E,0x86,0x72,0x59,0x85,0x73,0x71,0x84,0x80,0x30,0x31,0x70,0x7Aā, outClusters: ā0x5Aā
Can anyone advise/confirm?
(Withdrawn by author)
Yes and no. It is a what ST call a āgeneric fingerprintā. Once upon a time all Zigbee and Z-Wave fingerprints were expressed like this, but then there was a move to using āmanufacturer-specificā fingerprints. The end result was often a fusion of the two. Edge drivers are using manufacturer-specific devices for certified Zigbee and Z-Wave devices with some drivers having generic fingerprints as a fall back. So if you need device specific behaviour you really need the manufacturer-specific form.
Matter devices are interesting because although there can be āmanufacturer-specificā and āgenericā fingerprints it would seem that ST have actually been removing the former from some drivers, presumably because they ought to be redundant.
In the IDE for my Aeotec multi sensor 6 āraw descriptionā, I see this string of codeā¦ zw:L type:2101 mfr:0086 prod:0002 model:0064 ver:1.07 zwv:4.05 lib:03 cc:5E,86,72,59,85,73,71,84,80,30,31,70,7A,5A role:06 ff:8C07 ui:8C07ā¦ which hopefully identifies the sensor correctly for Edge migration (even though Iām using a custom DTH)
Your Multi Sensor 6 is supported by the built in Z-wave Sensor Edge driver.
- id: "aeotec/multisensor/6"
deviceLabel: Aeotec Multipurpose Sensor
manufacturerId: 0x0086
productId: 0x0064
deviceProfileName: aeotec-multisensor-6
Aeotec Group say here that they provide an Edge driver for the Aeotec MultiSensor 6 (ZW100).
Enroll in the channel here.
Sucks that they went the route of a separate driver for each individual device type. Curious if they did that under direction of Samsung or just on their own. Worried about resource usage on hubs for those of us with lots of different device types.
Pretty sure they do work with the stock Z-Wave drivers and provide basic functionality. But each manufacturer can provide additional features by setting custom parameters. AFAIK, these are not standardised between manufacturers. The Aeotoc drivers expose those parameters in the settings.
Iāve had one device migrate so farā¦ a sonoff snzb-03 zigbee motion sensor. Itās moved to a SmartThings zigbee motion sensor driver and appears onlineā¦ but doesnāt detect any motion now
@jds13 @csstup Thanks for your feedback guys. Iāve enrolled to the Aeotec channel and added the Edge driver as suggested. What now, do I wait for the migration then select Aeotecās driver? I donāt fancy un-enrolling the sensor myself then re-enrolling because too many automations are affected that would require rewriting (it controls all my lights using the lux sensor), so if waiting is an option Iād prefer that. I guess by waiting I get to check STās Edge driver, and if that doesnāt offer the refresh rate I require then select Aeotecās driver.
Just wait. You may want to rewrite your automations anyway but itās still best to wait for everything to stabilize.
If the ST-assigned driver doesnāt do everything you need, the Aeotec Multisensor 6 will be fully supported other channels including Aeotecās and Mariano Cacchiarelliās.
Hi @nayelyz
I can not create SmartApp anymore because the project type "Automation for the SmartThings Appā is gone.
Before, when I create a project, it looked like below
But now in the developer workspace, there are 4 types of projects below
I think SmartThings Cloud Connector may be close. And it has two options
SmartThings Schema and SmartApps
I want to create a SmartApps, but I donāt know how to create SmartApps because I tried two times, and they all are āSmartThings Schema Connectorā. Could you tell me how to create SmartApps āSmartThings Cloud Connectorā?
I followed the documentation here for SmartApps Get Started with Cloud Connected Devices | SmartThings Developers, but in step 4 my server redirect the link to https://c2c-ap.smartthings.com/oauth/callback?response_type=code&state=eyJhbGciOiJIUzM4NCJ9.MzYwNDEwYmMtOWU2ZC00NmYxLTkzNzctMjQ5MjQ0ODU2ZTlkOnZpcGVyXzVmMTEyNzIwLTY5M2ItMTFlZC1iNTY2LWM5ZDMwMWJhOWU5MDoxNjY5MDExODQzMTE2OjNjZGYwZmQyLTRkMWYtNDMzZi1hMGQ0LTA0YTcxZTQxN2JlMjplbjo.mxwtapxHTwA4M0hdn6JIaAJ3Gb57uC1ultEj59OoAudr9yF8cfSA2aK-tMykIn9D, and in step 5, it always told me āSomethins went wrongā¦ Request Code: 0WIFZFā. Different request code every time, but always wrong.
Can anyone tell me whatās the right redirection and is there any sample code I can follow?
I am really frustrated by this change and have no idea how to create an Automation connector any more.
Thanks for help
