Recently installed 2 heat recovery units with multiple MWR-WG00UN thermostats. When setting up the automation scheduling for the thermostats we have an option to set the unit to auto mode but it does not allow setting at temperature range such as 68-70. It only allows for a single set point. The option for set point ranges is available else where in the app when controlling individual controls but not though automation. Is there any available way to do this.
Probably not in the stock driver. What’s available in Routines is defined by the presentation for the device. You might find a community developed driver that supports that or you may request a driver that does it here.
