Temperature "Fibaro Motion Sensor" and SmartThings
(Bond007taz) #1
I have the Fibaro Z-Wave Motion Sensor and according to amazon it says that it does “temperature” readings. I got the Fibaro connected to SmartThings and it sees vibration and motion, but never shows temperature. The battery shows 100%. Does the temperature sensor of the “Fibaro Z-Wave Motion Sensor” work with SmartThings? I have an “Aeon Labs Aeotec Z-Wave Multi-Sensor” and it has a temperature option that does work with SmartThings and I have no issues with that.
I have reset the “Fibaro Z-Wave Motion Sensor” and let it sit for 6 days hoping it would sync up with temperature, no luck.
I removed the Fibaro Z-Wave Motion Sensor from my smartthings network and reset the battery and connected to back to my smarrtthings network and it still only sees the motion/vibration - which works great but no temperature…
should i return the Fibaro?
#2
Many community members are using it, but you need a custom device handler to get the temperature.
Much discussion and many people who have the device and can help you in the following topic:
If you don’t know what a custom device handler is in SmartThings, then read this FAQ first:
