trying to setup autolocation,sharptools, and tasker to improve my presence sensor. When setting up the awau profile i cant seem to get the task to show green status and looking at my activity feed on smartthings i keep seeing the notice of the arrive command constantly. Also having trouble getting my routine to fire along with this as well to close my garage door. Any ideas?
Without seeing your Tasker code, it’s hard to tells what’s going on. But if you’re at home, then the away profile should not be green. Have you set up geofences using Autolocation? If you’re continually sending arrival commands, then you’re probably missing an if statement like %st_attr_value !eq present in the goto loop of the arrive task.
