Hi everyone,
I’m using the SmartThings app on my Samsung Android device to control some Tapo devices, mostly lights and plugs. The plugs are the P100 and P110.
However, I’ve noticed that these plugs appear in the “Lights” section on the home screen’s dashboard. (see attached screenshot)
This misclassification leads to unintended control over the plugs when I intend to use the “off” button on the screen. I’ve attempted adjustments in the SmartThings IDE without success.
Also the select items menu does not work, since the following screen is blank. (see attached screenshot)
Has anyone else encountered this issue? If so, could you share any solutions or workarounds that have been effective?
Thanks for your time.
