Please see the new Tado (Connect) SmartApp for using your Tado Cooling Device with Smartthings
Iâd been after one myself so ended up putting a basic one together. It is still work in progress with the following limitations:
- Uses Tadoâs Private API accessible from their website so they could change it or disable access any time.
- Only read-only access at the moment to various stats from your Tado account.
- As I just have access to my own Tado device which is only used for heating in the UK (temperatures in Celsius and no air con)
- Donât have access to an iOS device so only been tested on the Android mobile app.
Here is the custom device type I created. Youâll need to create a new device based on this and fill in your Tado account details in the preferences section.
cool thanks for your help, i will try to work on the Tado Cooling integration and post back my results. i am getting slightly more confident having created a reliable Door Knocker with Sonos custom message that is working well with so far no false positives. but Device types are a whole new thing for me to look at
Thanks you are a gentleman and a scholar.
Regards
Stuart Buchanan
So i have created a new device type for the Tado AC Control if anyone is interested. I do not have currently Github integration due to the OAuth issue for us UK users, but here is the code of the device type, this works well.
Ian i have also been testing the implementation of sending temp changes and Mode statuses via put requests, i have had pretty good results for both the Tado Heating & Cooling products. I will add these into the code as soon as i can figure out the control options on the multi attribute tile.
Nice work Ian, works well on mine - are you planning on adding the ability to set temperature (and/or hot water :-))
Thanks.
James.
Thanks @xnetdude, Iâll be adding the set temperature but not sure about the hot water as I donât have that setup on mine either.
Good job @Fuzzyligic, though Iâm not sure how far you will get with multiattribute tile in the short-term. The reason I put it into lighting mode was that it seems to have a few bugs and ST appear to be still working on it. Hopefully it will change soon. (multiAttributeTiles in Android?)
Regarding Github integration, Iâve created a second account on the ST US servers purely for messing about with OAuth stuff. If you log out of the mobile app you should be able to create a US based account using a second email address. You canât access your hub but you can use the IDE and simulator without problems. It was also handy for working out workarounds for smart apps which required OAuth access.
thanks for the advice. As I said my smarthings hub is only just over a week old so have been doing lots of reading up on the IDE, groovy is very new me, not liking how flaky some of the stuff is on smarthings. But thereâs just not a viable alternative for me yet. I am using openhab for a lot of other stuff though like my voip telephones etcâŠjust need the oauth and IFTTT fixed to get them to collaborate.
As for the water heating, I have that on my boiler so can look into it if you want when I get a moment. Then I think a smartapp to tie the two devices together if someone has both might be the next move?
@Fuzzyligic - I have the tado for heating and hot water but planning on adding another tado for underfloor heating and also for aircon so would be interested in a combined app.
I have had ST for 24 hours and have been looking at adding the hot water and heating adjustments (am a developer by profession) to the great work previously posted here but happy to stand on the shoulders of other giants
Side note - the simulator is not working for me currently, anyone else have this issue? (nothing showing on the right-side of the IDE).
I have to say, I am rather liking this ST environment!
ps. Santa is (hopefully) bringing me an Amazon Echo for Christmas which I intend to tie together with ST, Hue and Sonos - reasonably excited!
well a developer is what we need. I just pretend to do development. Iâm an infrastructure monitoring consultant, my development experience is limited to getting values from things mostly using powershell or perl scriptsâŠin that sense using smartthings is similar. But thatâs the beauty of the system, contribute, collaborate and share.
Iâm impressed enough with the platform, but it is buggy, scheduling is a particular issue. Thatâs making me stick with openhab for a fair amount of stuff
@Fuzzyligic will this work in the US? I have the US Tado Smart AC control? Your device type looks good.
As far as i am aware Tado donât have different servers for different regions, and since the the device type doesn use OAuth in smartthings then i would say yes it should be compatible.
@Fuzzyligic do you know what this mean?
Org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: script14498664789421477189999.groovy: 81: unexpected token: ACMode @ line 81, column 5. def ACMode def ACFanSpeed def setPointTemp if (resp.data.acSetting.power == âOFFâ){ ACMode = âOFFâ log.debug("Read ACMode: " + ACMode) ACFanSpeed = âOFFâ log.debug("Read acFanSpeed: " + ACFanSpeed) setPointTemp = â0â log.debug("Read setPointTemp: " + setPointTemp) } else if (resp.data.acSetting.power == âONâ){ ACMode = resp.data.acSetting.mode log.debug("Read ACMode: " + ACMode) ACFanSpeed = resp.data.acSetting.fanSpeed log.debug("Read acFanSpeed: " + ACFanSpeed) setPointTemp = Math.round(resp.data.acSetting.temperature.celsius) log.debug("Read setPointTemp: " + setPointTemp) } sendEvent(name: âACFanSpeedâ, value: ACFanSpeed) log.debug(âSend ACFanSpeed Event Firedâ) sendEvent(name: âACModeâ, value: ACMode) log.debug(âSend ACMode Event Firedâ) sendEvent(name: âsetPointTempâ, value: setPointTemp, unit: temperatureUnit) log.debug(âSend setPointTemp Event Firedâ) }else if(resp.status == 201){ log.debug(âSomething was created/updatedâ) } ^ 1 error
Error when I created a device type?
For everyone who may need this in the future, i have created a Github site and uploaded the code there i will again start work on adding controls soon
Hi Stuart,
I have tried downloading from github as per post 17 but I am getting the following error.
Any ideas???
No signature of method: script14527166372241059700955.metadata() is
applicable for argument types:
(script14527166372241059700955$_run_closure2) values:
[script14527166372241059700955$_run_closure2@1c39d80f]
Possible solutions: getMetadata(), getState(),
setState(java.lang.Object), metaClass(groovy.lang.Closure)
is this error when you try at device type? If so you confirm that you copied the code the raw page on github, its known thereâs copy paste errors if you donât.
Hi,
Yes I went to the github site here:-
https://github.com/fuzzysb/SmartThings/blob/master/DeviceTypes/fuzzysb/tado-Cooling-AC.src/tado-cooling-ac.groovy
When I cut and paste it in, then press create, I get this message.
BTW. Yes, I clicked on the raw button to copy the code.
