Ok, a very stupid question:
When I use the code:
else if (cmd.event == 0x04) {
def timeString = new Date().format("MMM d yyyy, hh:mm:ss", location.timeZone)
result << createEvent(name: "tamper", value: timeString , descriptionText: "$device.displayName was tampered")
result << response(zwave.wakeUpV1.wakeUpIntervalSet(seconds:3600*wakeUpInterval, nodeid:zwaveHubNodeId).format())
everything is fine. But since the amount of code is getting more, I would like to use a custom function where to put all the code:
def resultConfiguration() {
And then only to call the custion function:
But it does not work when I do so and I have no idea what is wrong with the Groovy syntax.
What can be the problem?
geko
(Geko)
#2
In your resultConfiguration()
function, result
variable is not defined within the scope of the function. Therefore it won’t compile.
To elaborate on what @geko said, your second code block needs to have
def result = []
Your third code bock should then have:
result += resultConfiguration()
Of course! Thank you, guys.
And if the function contains the code:
cmds << command(zwave.wakeUpV1.wakeUpIntervalSet(seconds:3600*wakeUpInterval, nodeid:zwaveHubNodeId))
if (led) {
cmds << command(zwave.configurationV1.configurationSet(parameterNumber: 2, size: 1, scaledConfigurationValue: 1))
} else {
cmds << command(zwave.configurationV1.configurationSet(parameterNumber: 2, size: 1, scaledConfigurationValue: 0))
Should I use:
cmds += resultConfiguration()
You need to post a larger code segment, I can’t tell what you’re trying to do.
The function is:
def cmdsConfiguration() {
def cmds = []
if (led) {
} else {
Based on your input, I tried using:
cmds += cmdsConfiguration()
and it worked.
Thanks.
