I had the v2 hub with just a sonos attached. I haven’t done much with it yet, as I only got it 5 weeks ago. I now installed the WIFI connect home, which can include a hub. How can I migrate the sonos from the V2 Hub to the Wifi Connect? It doesn’t seem to work. I’m not sure the process.
OK, I found out how to do it using the online interface. Not sure how to do it from the smartthing app.
You can’t. You basically reset the hub and delete everything setup with it and then setup the new system.
Here’s the support article…
