Just a quick update to this old thread as suggested by @JDRoberts in my original thread Using remote button to turn on/off switches and set mode (Swann One Key Fob Remote Control SWO-KEF1PA, and ST Hub V3)
I’ve recently acquired the Swann One Key Fob SWO-KEF1PA, and I’m using ST Hub V3. I made a slight modification to the DTH so the “add a routine” and the smartlighting app in Automation would let me pick which button is pressed.
Here is the updated code.
* Swann One Key Fob
* v:1.00 - 12/31/2015 - Initial Configuraton
* v:1.01 - 03/11/2019 - Added numberofButtons reporting
* Copyright 2015 Rudimar Prunzel
metadata {
definition (name: "Swann One Key Fob", namespace: "RudiP", author: "Rudimar Prunzel") {
capability "Button"
capability "Configuration"
fingerprint profileId: "0104", deviceId: "0401", inClusters: "0000,0003,0500", outClusters: "0003,0501"
tiles {
standardTile("button", "device.button", width: 2, height: 2) {
state "default", label: "", icon: "st.unknown.zwave.remote-controller", backgroundColor: "#ffffff"
main (["button"])
details (["button"])
if (description?.startsWith('enroll request')) {
List cmds = enrollResponse()
log.debug "enroll response: ${cmds}"
def result = cmds?.collect { new physicalgraph.device.HubAction(it) }
return result
} else if (description?.startsWith('catchall:')) {
def msg = zigbee.parse(description)
log.debug msg
buttonPush(msg.data[0])
} else {
log.debug "parse description: $description"
def buttonPush(button){
//Button Numbering vs positioning is slightly counterintuitive
//Bottom Left Button (Unlock) = 0 and goes counterclockwise
//Securifi Numbering - 0 = Unlock, 1 = * (only used to join), 2 = Home, 3 = Lock
//For ST App Purposes 1=Lock, 2=Home, 3=Unlock , 4 = * (only used to join)
def name = null
if (button == 0) {
//Home - ST Button 1
name = "1"
def currentST = device.currentState("button")?.value
log.debug "Home button Pushed"
} else if (button == 3) {
//Away - ST Button 2
name = "2"
def currentST = device.currentState("button2")?.value
log.debug "Away button Pushed"
} else if (button == 2) {
//Night - ST Button 3
name = "3"
def currentST = device.currentState("button3")?.value
log.debug "Night button Pushed"
} else {
//Panic - ST Button 4
name = "4"
def currentST = device.currentState("button4")?.value
log.debug "Panic button Pushed"
def result = createEvent(name: "button", value: "pushed", data: [buttonNumber: name], descriptionText: "$device.displayName button $name was pushed", isStateChange: true)
log.debug "Parse returned ${result?.descriptionText}"
return result
def enrollResponse() {
log.debug "Sending enroll response"
"raw 0x500 {01 23 00 00 00}", "delay 200",
"send 0x${device.deviceNetworkId} ${endpointId} 1"
def configure(){
log.debug "Config Called"
def configCmds = [
"zcl global write 0x500 0x10 0xf0 {${device.zigbeeId}}", "delay 200",
"send 0x${device.deviceNetworkId} ${endpointId} 1", "delay 1500",
"zdo bind 0x${device.deviceNetworkId} ${endpointId} 0x01 0x0501 {${device.zigbeeId}} {}", "delay 500",
"zdo bind 0x${device.deviceNetworkId} ${endpointId} 1 1 {${device.zigbeeId}} {}"
return configCmds
def installed() {
initialize()
def updated() {
initialize()
def initialize() {
sendEvent(name: "numberOfButtons", value: 4)
