Sunscreen automation
I have 3 sunscreens controlled by the Fibaro Roller Shutter 3. That works as a charm, and my next step is to make them smart. Using the SmartWeather Station Tile, I would like to use Illumination from this to take the blinds up and down, so I made an animation in the the new app.
I made it like this; if time between 7:30 - 11:00 and Illumination less than 7499 Lux, then close the shutter. But this does not seem to work. Only if I change the rule to check at one specific time, does ist takt the screen up or down.
I also tried to look for the same possibility in the old app, but it does not seem to be able to check time and illumination together.
So does anyone have any ideas? It would be great if the screens could go up and down based on the sunlight automatically.
Are you not using WebCoRE yet? I would use that, then the possibilities are endless, you could use luminance, rain, anything you wanted.
No, what is that?
I would have a look around their forum, especially the Examples section.
See the following. (The topic title is a clickable link)
Thanks :smiley:
