I would have to add entries to choose date1 MMDD and date2 MMDD.
It could also be useful to have 2 day of the month entries to be able to automate day ranges without taking month and year into account.
i will add it
i will add it
It does not let you choose another type of keyboard in settings?
It does not
New version of the Virtual Calendar Mc driver.
At the request @jkp, of I have added 5 new capabailities to be able to automate more cases of time periods:
The update will be automatic, but be attentive because I see on one occasion when updating the entered value of the offset of the Local time with respect to UTC was lost and it would have to be re-entered as soon as possible, since it calculates everything with the UTC time and the automations made would return crazy
I do it automatically because I have repeated the update process several times and the problem has not happened again, although I have communicated it to smartthing. If this happens to anyone please let me know.
UPDATE: this is correct version
Virtual Calendar Mc
2022-06-17T15:30:53.256179558
I updated the driver and I lost offset of local time to UTC
Also updated driverâs version is different
Would it be possible to show time as 12-hour instead of 24-hour/military format?
Sorry,
He re-published the version, I donât know why sometimes it doesnât publish well
Virtual Calendar Mc
For the automations to make comparisons, the emitted value must be a numerical value that can be ordered from highest to lowest, for date and time.
The time in the form am, pm is a string and would not show the comparison option => or =<
Makes sense, thanks!
I updated driver again using CLI and now driver version is
Thank you!
I expected this Edge Calendar device would have local execution compared to the native Time settings for Routines, but Iâm not seeing the local execution ICON on my Routines when using above our below calculations. Does it execute local even though there is no local ICON, or is this still a SmartThings limitation?
All >= or <= comparisons continue to run in the cloud.
Hopefully this will change at some point by surprise!
I am noticing that when I use sunset or sunrise with offset matches 0 min my automations are not running.
Am I using this wrong?
I know I can change it to equal or above but then it doesnât run local.
Hi @Terri_Baker
I tried a simple routine, turning on a switch with sunset offset = 0 and it worked fine.
Would you mind sharing a screenshot of how you wrote this rule please?
I have it done like this.
In Spain, the winter time is changed on the last Sunday of October, at 3 a.m. it happens to be 2 a.m. (+1 hour UTC)
I do pretty much the same as @Mariano_Colmenarejo , except I added notification, just a reminder to setup next time change
Great Job (again) !!!
I was looking for this because I use Webcore for most of my automations, and I new to use the âMonthâ option, for example⊠And I think that Webcore will die
One other thing I need is to access my Google Calendars to make automations.
For example, I have a Portugal holidays calendar. Depending if itâs a holiday or not, my automations will work accordingly, using virtual devices.
@Mariano_Colmenarejo Is there any chance for you to make a driver that can read Google Calendar events??
This is what I use: GitHub - infofiend/GCal-Search: Re-Release of mnestor's G-Cal Search App
Forum: [UPDATED 3/27/18] GCal Search
Sorry, this is out of my knowledge
Hi, Iâve used this too. Now I moved my calendar based automation to IFTTT. I combine the Google calendar with virtual switches and then use the switch state in the automation.
Hope this helps.
