The Harmony (Connect) smartapp has the ability to create a virtual switch for each activity defined on your Harmony hub.
To do this, it presents a list of those activities.
A problem arises when you have multiple hubs and you have identically named activities on two or more of those hubs.When this occurs, when the smartapp presents the list of activities there is no way to discern which activity belongs with which hub.
This is not an uncommon situation as activities often have names such as “Watch TV” or “Listen to music”.
I prefer not including the location/hub name within the name of each activity, as the activity name also appears on the LCD display of the physical remotes, where space is very limited and maintaining clarity is paramount.
Suggestion:
When listing the activities, suffix the activity name with the hub name enclosed in parentheses. Carry this over when setting the name for the virtual switch as well.
Alternatively, list the activities using a tree hierarchy, so the activities appear as branches below their respective hubs; you would, however, still need to resolve the naming of the virtual switches.
