Suggestion for Dimmer Levels in Mobile App
(Bruce) #1
@April, @Ben, et al
The mobile app, in both Lights & Switches and Hello Home phrases, uses an enumeration [10,20,30,40,50,60,70,80,90,100] to select dimmer levels. People are hitting a road block when they need a dimmer level less than 10%. It would be just as easy if, instead of an enumeration, you allow the dimmer level to be input as a number, with the description “0 - 99”. The Dimmer Switch device type protects itself against out of range numbers, as can any app. This would open up things like 25% and 33%.
