Suggest a Device
Please, add support of Danfoss Z-Wave Radiator Thermostat (LC-13). Or Radiator Thermostat STELLAZ. But Danfoss better. Thanks!
  1. Scene Controllers (Leviton
    Vizia RF + 4-Button Scene Controller)
  2. Lutron Smart Bridge Pro - enabling support for Caseta lights and blinds
  3. Nest - Smoke Alarm and Cameras
  4. TrackR Atlas and TrackR Bravo tags
  5. iRobot Roomba 980
I believe 5 exists already with a community solution, and I know 3 does as I use it and it’s brilliant.
I could have missed a community integration for this, but afaik the roomba wifi series 900 wont work with the thinking cleaner integration.
Edit: looks like there has been some progress, but still no device type for the 980.
Relevant roomba 980 thread: Roomba 980 Wifi Connectivity Reverse engineering
I have a question hopefully someone can answer. Are there any light switches which are considered “local” devices?
Here is my scenario. I have a room with two light switches (which we’ll call A and B) which control separate sets of lights. When the room was remodeled, I would’ve preferred that one switch controlled both but it was too hard to do for a variety of reasons which I won’t get into. What I would like to happen is that when you turn switch A on when entering the room, switch B will also automatically turn on.
I’m currently doing this with Wink and two Lutron Casetas, but there is significant lag before the second switch turns on. I was hoping to replace those with two SmartThings-compatible switches and eliminate most of the lag. Thoughts?
That would be going pretty far off topic for this thread, but start a new question under devices, and you’ll get lots of answers. The short answer is, sure, any zwave switch on the official compatibility list is eligible to run local. And “smart lighting” automations (that’s an official feature), which are eligible to run local, could tie the two together.
That said, it won’t necessarily be faster than the cloud-based implementation, but again, start a new thread and we can discuss why. It should still be faster than the Wink set up, though.
Thanks JD! Sorry, I thought this was the general thread to ask for device suggestions.
It is, but you’re getting into specific questions about existing devices, in particular local operation of particulae zwave switches. That’s a whole different kind of discussion. :sunglasses:
So I just think you’ll get better answers if you set up your own thread where we can really discuss why the answers are what they are for different brands.
IntesisHome
I have 2 of these, and would love to be able to fully utilize them with my ST V2.
Samsung Smart AC Heater
I mean… A SmartThing should be compatible with Samsungs other Smart line…
Lutron Caseta - It would be great to have it work with Smartthings becuase for those who don’t have Neutral wires in their switch boxes can use this instead and not go and try some untrusted Z-Wave switch that doesn’t require a neutral wire. This can be added using a Hub-to-Hub Connection. Lutron Caseta has its own hub so Smartthings can tell it what to do and the Lutron hub can control the lights until Smartthings creates a hub that has Lutron RF built in that controls the switches directly.
@Amrutha [quote=“Amrutha, post:794, topic:6578, full:true”]
is LeakSmart Rough Brass Quarter-Turn Straight Valve from Lowe’s compatible with SmartThings?
[/quote]
Yes:
-LeakSmart Sensor @whoismoses : https://community.smartthings.com/t/leaksmart-water-sensor/51505?u
Hi. Please add compatibility for Monoprice 11990 Dual Relay Module. It’s by far the least expensive way to add smart switches ($15 each switch at full price vs $30-$80 for other switches).
http://www.monoprice.com/product?c_id=122&cp_id=12212&cs_id=1221201&p_id=11990
ZooZ 4 in 1 sensor ZSE40
https://amzn.com/B01AKSO80O
I’m using a community solution that is working but official support would be nice. Thanks.
I would like to suggest Venstar thermostasts as a compatible Smart Things device.
if possible i would like you to consider the ID-LOCK.
www.idlock.no
its very nice lock who just released their z-wave module.
my guess its gonna be a big compettion to Yale locks here in scandinavia.
im sorry, but the webiste is only in norwegian.
I just bought the Zigbee Version, via the only method Baldwin said I could, which was a Control4 distributor. It seems to be similar in design to the Kwikset SmartCode 914. I bought it thinking ALL Zigbee advertised devices would work with the ST Hub, Well I eventually got it to work, after a combination of adding a device from my phone and selecting the proper device from “Zigbee Lock” from the Web Panel Interface. All was good, even showed the family. Went to use it an hour later and no dice…
I’ve tried adding the different Kwikset Models (Zigbee Radios) the best I have gotten is this…
Now I will guess no one will claim the integration, so yeah me. I’ll be calling Baldwin/Kwikset/Black & Decker tomorrow to see what they say. There seems to be two versions of the 914, a straight-up Zigbee with all the right specs, Zigbee, Home Connect and most importantly HA 1.2 compliance (HA 1.0 in their website) I am hoping it’s the same radio in the 8285.###.AC2. It looks too similar to not be.
Here are links to the technical documents for adding to what the refer to as a “HAN”.
Kwikset Install Guide --> [http://s7d5.scene7.com/is/content/BDHHI/914zb-installation-user]
(http://s7d5.scene7.com/is/content/BDHHI/914zb-installation-user)
Kwikset 914 - Control4 --> http://s7d5.scene7.com/is/content/BDHHI/Kwikset/Tech-Docs/HomeConnect/914-data-control4.pdf
Kwikset 914 - Zigbee --> http://s7d5.scene7.com/is/content/BDHHI/Kwikset/Tech-Docs/HomeConnect/914-data-zigbee.pdf
Baldwin ####.###.AC2 Install Guide–> http://s7d1.scene7.com/is/content/Baldwin/deadbolt-installpdf
Here is the best part, their “HomeConnect” guides are the exact same form. http://s7d1.scene7.com/is/content/Baldwin/rf-instructionpdf
As I am writing this, it is working intermittently now, so I’ll try to see in a log file gives a clue. Here’s what I found, it trying to send to it, but it does not react. I also found out I am impatient, as one can see from the senseless button pushing.
Is Smartthings planning on integrating the D-Link DCS-960L HD 180 degree wi-fi? I recently purchased this camera and will likely take it back if it won’t eventually integrate with my Smartthings.
