Hello! Our front door uses a TTLock keypad and a strike lock. Does anyone suggest a way that once the door is unlocked via the strike lock power supply and or the keypad that it could start a routine/scene/turn off the alarm etc in SmartThings?
Is it connected to SmartThings ? (I see it’s a bluetooth device)
It does have a (Bluetooth to WiFi) hub and and an Alexa skill.
Unless you can connect it to SmartThings you’ll have to use some sort of an external device.
For example you can connect a contact sensor to your door so it’ll trigger when the door opens. Now you can use that contact sensor to trigger a routine or scene.
You can also use a strip contact sensor for your door.
