Hi, I would like to know if there is a device that can monitor stove usage. I have an electric stove. I can’t find something that is compatible with my stove.
You could install an energy monitor clamps like this Aeon Labs meter.
Unless you also want the control it as well. Then consider this 40Amps switch. Not sure what’s the rating for your stove but it should be on the metal label. I don’t see it on the online spec.
