I’m not a programmer, but I do generally have the ability to customize and combine existing code to do what I want with it. However, I’m pretty stumped on this one. I’m using something mostly based on SmartThings’ Hue Mood Lighting and Dan999’s power monitoring code here: Say goodnight when you turn off your night stand light
I have a SmartThings Outlet which my projector is plugged into. I want to monitor that outlet, and when it detects that I have turned on the projector, I want my Hue bulbs to dim to a 1% purple. When I turn the projector off, I want the lights to go back to whatever their previous state was.
It’s that last part that I’m having trouble with. No matter what I try, I can’t seem to figure out a way to save the previous values in order to go back to them later. I’m sure I’m missing something stupid, but if anyone can help out with this it’d be appreciated. Here’s what I’ve got - currently have it hardcoded to return to a daylight color at 100% brightness after the projector turns off, since I can’t figure out anything else.
definition(
namespace: "jhoff80",
author: "jhoff80",
description: "When the projector is on, change the Hue colors. Code based on SmartThings' Hue Mood Lighting and dpvorster's Good Night.",
category: "Convenience",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Partner/hue.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Partner/hue@2x.png"
preferences
page(name: "settings", title: "Settings")
def settings()
dynamicPage(name: "settings", install: true, uninstall: true)
section("Outlet to Monitor") {
input "switch1", "capability.powerMeter", title: "Where?"
section("Wattage for On State") {
input "wattage", "number", title: "Power Draw", required: true, defaultValue: '50'
section("Control these bulbs...") {
input "hues", "capability.colorControl", title: "Which Hue Bulbs?", required:true, multiple:true
section("Choose light effects...")
input "color", "enum", title: "Hue Color?", required: false, multiple:false, options: [
"Daylight","Warm White","Red","Green","Blue","Yellow","Orange","Purple","Pink"]
input "lightLevel", "number", title: "Light Level?", required: false
section ("") {
label title: "Assign a name", required: false
input "modes", "mode", title: "Set for specific mode(s)", multiple: true, required: false
def installed()
initialize()
def updated()
initialize()
def initialize()
unsubscribe()
subscribe (switch1, "power", eventHandler)
log.debug "Subscribed to power event for $switch1"
def eventHandler(evt)
log.debug "eventHandler, wasOn=$state.wasOn"
if (! state.wasOn)
state.wasOn = (switch1.currentValue('power') > wattage)
if ( state.wasOn)
takeActions()
private takeActions(evt)
if (isPowerOn())
def hueColor = 0
def saturation = 100
switch(color) {
case "Daylight":
hueColor = 53
saturation = 91
break;
case "Warm White":
hueColor = 20
saturation = 80
break;
case "Blue":
hueColor = 70
break;
case "Green":
hueColor = 39
break;
case "Yellow":
hueColor = 25
break;
case "Orange":
hueColor = 10
break;
case "Purple":
hueColor = 75
break;
case "Pink":
hueColor = 83
break;
case "Red":
hueColor = 100
break;
state.previous = [:]
hues.each {
state.previous[it.id] = [
"switch": it.currentValue("switch"),
"level" : it.currentValue("level"),
"hue": it.currentValue("hue"),
"saturation": it.currentValue("saturation")
log.debug "current values = $state.previous"
def newValue = [hue: hueColor, saturation: saturation, level: lightLevel as Integer ?: 100]
log.debug "new value = $newValue"
hues*.setColor(newValue)
if (! isPowerOn())
def hueColor = 53
def saturation = 91
def lightLevel = 100
hues.each {
state.wasOn=false;
private isPowerOn(evt)
def power = switch1.currentValue('power')
log.debug "Power is $power"
power > wattage
