it would appear that on their last update, Smartthings changed something that affected your z-wave handler again.
It’s no big deal this time as everything still works perfectly, but the green circle in the bottom, middle tile only says “setpoint” in really small letters.
You can still see your setpoint in between the arrows though.
Hello, please excuse my ignorance in the following question. How do I apply this device handler? I’ve got a Samsung Smarthings hub Rev 2 and a light switch working via Echo Alexa by calling routines created in the Smarthings app.
I cannot get Alexa to change the temp routine which it looks like this device handler handles, but I don’t know how to apply it.
Thanks Eddy for the info. I got the new Device Handler installed and it works way better than the original, BUT still doesn’t solve the problem. Bummer.
i installed this smartapp (thanks for developing for the platform!) but im not sure i understand what it does exactly.
here’s my guess after trying it… IF you have a remove temp sensor on one of your stelpro’s, you can display that reading on other stelpros so you don’t have to have a remote sensor on them all. is that it?
i connected thermo 1 to thermo 2. thermo 2 had a setpoint of 52 and ambient reading of 60, but the ext on termo 1 said 57. not sure where the 57 was coming from…
Is it possible to set the thermostats temperature with google home? I just installed two of these and it replies that the device doesnt have that feature, using the device handler linked in this thread.
Any estimate if that will ever happen?
Because it seems weird that at this point I have to choose between @JCon 's solution and lose the exterior temperature or keep the “Official” handler and lose Google Home control…
We are working on it.
I have reached @JCon in order to understand how he managed to make our device handler Google Home compatible.
He agreed to collaborate with us, so you may expect something soon.
I am ready to grab a couple of these for the condo. I am curious to find out if there will be an app to allow 5-2 schedule or programming similar to apps wrote by RBoys?
I want to be able to pre-heat the home at 5am in the morning and 3pm in the afternoon that kind of automation.
